shifting problem? - Mustang Evolution
Old 09-30-2010, 05:48 PM   #1
Question shifting problem?
I just bought a 1992 mustang from a friend of mine and it shifts good when i drive it normally and when i get down on it from first to second, it sounds like the gears are grinding a lil bit. I drained the trans fluid to see if that would help but it didn't. I've asked around and people are sayin that i need to replace the sinkanizer( srry i can't spell it) can someone give me some helpfull advise?
black bullet is offline   Reply With Quote
Old 10-01-2010, 07:37 AM   #2
Re: shifting problem?
yea sounds like the syncro is bad or going bad, you can rev a bit to help it ease in as the syncro is what lets you go into another gear easily vs rev matching since the gear is different in size.
Old 10-01-2010, 07:55 AM   #3
Is it easy to replace?
Old 10-01-2010, 09:51 AM   #4
well it requires removal and dismantling of the transmission so not easy but you can live with it for a while im sure~ reving it up to shift will help but it will take a little getting used to to find the sweet spot usually its not a ton of reving just a little.
Old 10-01-2010, 09:57 AM   #5
R the cyncernizers expensive?
Old 10-01-2010, 09:57 AM   #6
Sounds like to many speed shifts or gear jamming has been done on that car. If you know someone that can fix it rebuild kits won't cost to much around $200 at most parts stores.
Straublittleman is offline   Reply With Quote
Old 10-01-2010, 10:00 AM   #7
And it depends on the mechanic on how much labor cost are, I only charge $150-$200 to rebuild most five speed if the person buys the rebuild kit.
Old 10-01-2010, 10:12 AM   #8
Where r u located
Old 12-16-2010, 08:28 AM   #9
I actually have the same thing goin on with my 91 gt and the dude who suggested reving a lil bit before shifting was right on the money my car mainly does it when it's cold but i was glad to hear of a possible solution to my problem... thanks it's my first day using this app so I'll b on it a lot now
Yankeeblu91 is offline   Reply With Quote
Old 12-18-2010, 12:57 PM   #10
Blustreek's Avatar
Region: Hawaii
Hey double B sorry man but to save you anymore shame
the word is "SYCHRONIZER".There's a PRIMARY & a
SECONDARY sychro.It's sole purpose is to guide and hold shifter in gear under load.Again "no offense dude" just bein'
a friend.Don't know if they're costly,checked Summit but didn't see it.Go online and check it out,try typing in "gear sychronizer for 1992 mustang" and see what you get from
ur browser.
Blustreek is offline   Reply With Quote
Old 12-18-2010, 03:01 PM   #11
roger306's Avatar
Region: New Mexico
Your best bet to buy synchros is from Astro performance they have great prices and friendly
roger306 is offline   Reply With Quote
Shifting problems blue-saleen Pre-2005 V6 Mustang 4 09-08-2009 07:55 PM
Cluthchless Shifting 2000StangLover Mustang Audio & Video 15 10-28-2008 03:44 PM
Flat Shifting doinurx 1996-2004 Mustang GT 41 05-13-2007 08:58 AM
shifting problema 95stang_man Pre-2005 V6 Mustang 3 07-28-2005 11:37 PM
Shifting on Automatic megax29 Pre-2005 V6 Mustang 52 07-15-2004 11:14 AM
08:31 AM
