oil pressure help - Mustang Evolution
Old 05-22-2007, 07:33 PM   #1
oil pressure help
i just noticed it today riding down the road in my 88 mustang. i was driving and when i shifted to neutral coast the oil pressure would drop below 0 very quickly. but when in gear it would go up about 2 bars instead of 3. when say driving at only 45 in 5th the pressure would also drop to 0. at the same time the enigine doesnt run any different,no smoking, over heating nothing. could this be a problem with the pressure switch.or is the pump going.
jesse4887 is offline   Reply With Quote
Old 05-22-2007, 10:08 PM   #2
Re: oil pressure help
I'd put a real oil pressure gauge in. The stock ones are known to go out.
Spend a few bucks and put a good gauge in, then you'll know what's really going on.
Old 05-25-2007, 02:41 PM   #3
silverstangboy's Avatar
the stock gauge on certain models also only work like an on off switch, either reading normal or zero, but not in between.. so basically if you go under a certain pressure the units going to peg out on you.
93 mustang notch
~450hp 331 stroker - Sold
Old 05-25-2007, 03:38 PM   #4
MonteCitan's Avatar
get a mechanical gauge on there ASAP
Mine rarely drops below 45 PSI, even at idle..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-25-2007, 04:20 PM   #5
Zim
You want to **** me?
Zim's Avatar
sounds like your sending units goin bad
I like toys
Old 05-28-2007, 07:34 AM   #6
Titus Wadicus
svtlx's Avatar
uh oh, sounds like i need some cam bearings then...when mine warms up it drops to 30, and i'm run'n a high preesure oil pump, so u know it's bad.
Old 05-28-2007, 12:11 PM   #7
bullitt482's Avatar
/\ Yep, I'm running 10w 40 and it usually runs around 30-32 at idle after it warms up.
Agree totally with a aftermarket gauge.
01 Bullitt
Old 05-29-2007, 07:49 AM   #8
Titus Wadicus
svtlx's Avatar
sooo, is 30 normal?....it goes close to 40 on the highway....i have an aftermarket mechanical on it. or should it be around 60lbs. like chevies?
Old 05-29-2007, 08:24 AM   #9
On my 01 v6 my oil pressure would be around 75 just driving around... I looked around about it and others were as well.
Old 05-29-2007, 08:32 AM   #10
Titus Wadicus
svtlx's Avatar
yea, but u got a totaly differnt engine....i'm try'n to find out for a 5.0.....it probably needs to be around 60 i bet....i need to pull some of my books out to make sure i guesse.
Old 05-29-2007, 03:59 PM   #11
bullitt482's Avatar
30-40 at idle(800ish rpm) is just fine. A rule of thumb is you want 10 psi of oil pressure for every 1000 rpm(ex. 5000 rpm at 50 psi). I know at about 3 grand I have well over 60 psi.
Some hi performance engines actually run a little less oil pressure since they tend to have super duper awesome flowing oil systems that have been bored out and fixed up by the engine builder.
01 Bullitt
Old 05-29-2007, 04:26 PM   #12
bbunt302's Avatar
My 5.0 idled around 35 if I remember right.
Scary stuff.
Old 05-29-2007, 04:46 PM   #13
MonteCitan's Avatar
high volume pumps ftw... usually around 60-65 when cruising or WOT
Old 05-29-2007, 04:49 PM   #14
bullitt482's Avatar
I hear a lot of guys don't bother with High volume pumps because at WOT, they sometimes get oil starvation from sucking the stock pan dry. I've always gone by stock pump, but hardened shaft.
I'm running a stock pump, but get that same 60 plus PSI at cruising speed(70). :dunno:
01 Bullitt
Old 05-29-2007, 04:55 PM   #15
bbunt302's Avatar
I've heard the same. From what I understand for a street car, high volume is fine, but high pressure is a waste. Plus, it takes more horsepower to operate a high pressure oil pump (believe it or not).
Scary stuff.
Old 05-29-2007, 09:13 PM   #16
My truck runs 9 psi at warm idle...
And has been doing this for as long as anyone knows lol...
Old 05-30-2007, 01:44 AM   #17
Zim
Zim's Avatar
My car did that a while back... just found out i have a blown rod bearing. ITS REBUILD TIME. 347 stroker here i come!
I like toys
Old 05-30-2007, 05:59 AM   #18
Titus Wadicus
svtlx's Avatar
that's the whole thing guys...i'm run'n a "high pressure pump" and still only idle at 28-30lbs...now that i think about it...my idle is set @650rpm...it does go to 38-40 on the highway though....my friend said that if i had a stock pump that i would be lucky to see 20lbs at idle.
Old 05-30-2007, 10:49 AM   #19
MonteCitan's Avatar
Stock pan???
who uses a stock pan anymore? :pnoid:
Old 05-30-2007, 03:43 PM   #20
bullitt482's Avatar
Originally Posted by MonteCitan View Post
Stock pan???
True true,
Svt, your friend is not the brightest crayon in the box. If you are only running 20 psi at idle, something is up. 30 to 40 is still based on stock everything.
01 Bullitt
Old 05-30-2007, 03:49 PM   #21
MonteCitan's Avatar
Oh and as for stock gauge accuracy... I have both mechanical and stock hooked up.. mechanical goes from 45-50 at idle to 60-65 tops while cruising/WOT... and the stock gauge stays around the second bar, regardless...
in other words.. put a mechanical gauge on there to see what your oil pressure is actually doing...
Old 05-31-2007, 06:45 AM   #22
Titus Wadicus
svtlx's Avatar
True true,
no, no, no...that's "if i was running a stock pump"...i am runn'n a " high pressure pump". his point is basicaly wut u r say'n. if it only runs @ 30lbs. with a "high pressure pump" then it would probably run lower with a "stock pump" which like you said, is a problem.
Old 05-31-2007, 01:54 PM   #23
Herbstang's Avatar
maybe try thicker oil 20w50 the bearing's are worn so oil presure drops with thinner oil
Old 05-31-2007, 02:03 PM   #24
bullitt482's Avatar
Agreed, I went up to 10w 40 here.
01 Bullitt
Old 06-01-2007, 06:11 AM   #25
Titus Wadicus
svtlx's Avatar
yea, i think the bearings r shot....20w50 is wut's in it now....i even used that oil that is thicker than 20w50...don't remeber wut it was but i can't find it anymore. that's ok, i just got a new rebuilt bottom punched .30. i started yank'n the cam outa my old block last night.
Old 06-01-2007, 10:39 AM   #26
Herbstang's Avatar
NO OIL PRESSURE bmxrr1990 Pre-2005 V6 Mustang 11 11-23-2009 10:04 PM
Oil pressure gauge Scut95 1979-1995 Mustang GT 12 03-24-2008 07:08 AM
Oil pressure going crazy Zim Pre-2005 V6 Mustang 9 11-17-2004 10:28 PM
11:01 AM
