Will not start when hot - Mustang Evolution
Old 05-24-2007, 12:15 PM   #1
I have 93 5.0 that runs great (mostly factory). Problem is, once I cut it off it will not start back up until it has completely cooled down. Even when I get gas I have to leave it running becuase if I turn off the car it will not start back up. I've replaced just about everything under the hood (coil, wires, plug, dist cap, dist module, O2 sensors, etc, etc). I've read a few things about this problem but most threads seem to be about 5.0's cutting off while driving. Do I need to wrap the fuel lines with installation or is something else going on? I've just replaced the convt top, windsheild and carpet and now I this pain in the *** problem...
SJLOGAN is offline   Reply With Quote
Old 05-24-2007, 01:06 PM   #2
Herbstang's Avatar
Re: Will not start when hot
Are you running after market headers ?? My buddys used to do the same thing the starter was getting hot from the headers. He wrapped the headers and solved the problem
Old 05-24-2007, 05:38 PM   #3
silverstangboy's Avatar
good suggestion herb
i'd also replace the whole distributer and not just the TFI module.
the thing to do would be to run it, let it get hot and then test it.
it will always be one of these things
1. car has jumped timing (highly unlikely)
2. car is getting insuficant fuel (unlikely)
3. car is getting insuficant spark (unlikely)
4. car is getting insuficant compression (highly unlikely)
5. engine is not turning over fast enough during start trial
let us know which problems you have and we can better help you.
93 mustang notch
~450hp 331 stroker - Sold
Old 05-24-2007, 09:59 PM   #4
Kiljosh's Avatar
What about a dirty air filter. I have seen that a few times when I worked at a full serve station.
Old 05-24-2007, 10:03 PM   #5
bbunt302's Avatar
Replace the starter. My 91 GT used to do the same damn thing. It would crank fine when cold, but would barely turn over when it got hot. Heat soak is a starter's worst nightmare.
Scary stuff.
Old 05-24-2007, 10:12 PM   #6
MonteCitan's Avatar
yeah its starter... when its hot it won't work
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-25-2007, 06:52 AM   #7
Weird thing... It spins over but just doesn't fire. But it doesn't spin over all the time. I think I go with replacing the starter and see about getting a heat shield also. Thanks for the replys/advise. I'll get a starter this weekend and post an update.
Old 06-03-2007, 09:02 AM   #8
I'm running BBK long tubes, and mine cranks very slowly when it's hot. I'm going to have to wrap my headers.
1992 GT
Edelbrock Performer Heads/RPM II intake
Vortech S-trim/Aftercooler
Kenny Brown suspension
Too many mods to list
480rwhp/480rwt
1hawaii50 is offline   Reply With Quote
1995 GT cranks but no start hot 89beretta 1979-1995 Mustang GT 9 07-26-2009 08:23 PM
Hot start idle issues Scorpion1 Pre-2005 V6 Mustang 12 04-07-2009 04:58 PM
Where to start? Jay Dawg Pre-2005 V6 Mustang 10 08-12-2008 07:20 PM
hot!!!!!!!!!!!! matthewh 1979-1995 Mustang GT 11 06-05-2008 09:38 AM
Now this is hot PureVenom Pictures and Videos 23 03-13-2007 07:43 AM
07:58 PM
