what in the world is going on - Mustang Evolution
Old 05-26-2007, 10:52 AM   #1
Sassa Massa's Avatar
Last night I was out and the car was running fine. Parked it and went to a club. When I came back out the damn thing wouldn't idle. If I didn't hold down the pedal a little bit it would stall and die. I gave it a good run to see if it would clean itself out and when I hit the pedal to the floor it hesitated for a few seconds and then took off like a bat out of hell. It did this all the way home. It did stop stalling on me but it was really jerky power, not a smooth surge but more peaky like a two stroke dirt bike or something. I dunno if my fuel filter is getting dirty or what's going on so if anybody could help me out and steer me in the right direction I would greatly appreciate it.
Sassa Massa is offline   Reply With Quote
Old 05-26-2007, 11:08 AM   #2
meteorachick's Avatar
Re: what in the world is going on
imo it sounds like you are droppin a cyllinder, but i could be wrong, one of the guys on here should know what it is
Modified 2004 V6
Old 05-26-2007, 11:12 AM   #3
I don't think it's that, but I could definitely be wrong because it ran like a top when I parked it but went all funky when I got back in it. Some idiot could have pissed in my gas tank for all I know. It got better the more I drove it, but it didn't go completely away. I did have the gas tank down pretty low one day so I'll try the fuel filter first cause they're pretty inexpensive and I'll go from there. Still open for suggestions and info! Thanks.
Old 05-26-2007, 11:16 AM   #4
i was gonna say another possibility could be water in your fuel, cause that could definately do it as well
Modified 2004 V6
Old 05-26-2007, 03:47 PM   #5
ok so i have some new findings. I changed the fuel filter and the old one was definitely not as good as it should have been but the car is still acting weird. It idled for 10 minutes at one time and then just shut off. When it's acting up like that the only way you can get it to start is to hold the accellerator to the floor, otherwise it won't start, just kick and stall. The only thing i can think of is the fuel pump is getting weak, but again i'm no mechanic. oh and the check engine light did come on for a second. any help as soon as possible would be greatly appreciated. Thanks
Old 05-26-2007, 06:56 PM   #6
Clean/replace the idle bypass valve (IAC valve) it is a round cylinder thing located on the throttle body or upper intake. You should also clean the MAF with on contact NO residue electronics cleaner. See if that helps.
Old 05-26-2007, 07:25 PM   #7
I will definitely try that out, and will let you know how it goes.
Old 05-26-2007, 10:41 PM   #8
MonteCitan's Avatar
hesitation when you hit the gas and poor idle sounds like MAF to me.. what year/model/trans?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-27-2007, 01:20 AM   #9
347snake's Avatar
yeah i would def check the iac valve my 93 use to do that and i took it off and cleaned it and it worked fine posible the maf if neither one of those then i would say a fuel prob
347snake is offline   Reply With Quote
Old 05-27-2007, 05:31 AM   #10
mine is a 95 GT with a standard tranny.
Old 05-27-2007, 11:13 AM   #11
My 01 manual mustang would just die and not idle at all, but it mainly did it when it was cold outside. Maf would be the first thing as it wont cost you much then the iac (you can try to clean it as well but i think there is a seal you might have to replace.
Old 05-27-2007, 11:39 AM   #12
rocknbronco's Avatar
I'm saying MAF.
rocknbronco is offline   Reply With Quote
Old 05-27-2007, 06:40 PM   #13
well i cleaned the iac and now it's running fine, so hopefully it will stay that way. Thanks for everything!
Old 05-28-2007, 05:18 AM   #14
well it messed up again this morning, it idles up and down and that's what it was doing friday night when i first got in it. I assume that since I cleaned the iac and it ran good for a bit then that is the problem? ahh i hate electronics lol.
Old 05-29-2007, 07:55 PM   #15
well ladies and gentleman, to all of you who said MAF......you were right. What a difference even in accelleration, this thing must have been going bad over a while cause she gets up and goes quicker than it did before. it goes through the rpms much quicker than before. before you know it you're flying down the road faster than you think. Thank you again to everybody who helped out!
Old 07-06-2007, 04:11 PM   #16
bluestang1724's Avatar
i am having the same problem with mine i took it to a shop and they said it was the maf and its not holding fuel pressure so i need a maf, fuel pressure regulator, and a fuel pump. so hopefully that fixes everything
car: 2000 v6 5-speed
1995 cobra svt
bluestang1724 is offline   Reply With Quote
In a world... MarkuzLS1 Pictures and Videos 8 06-01-2008 09:20 AM
Who's in the World Series JROC The Bar 24 10-27-2006 10:08 PM
Its the end of the world!!! maximus The Bar 13 07-16-2006 03:34 PM
New of Ebaum's World Seph The Bar 9 02-05-2005 09:00 PM
It's a small world... Dom The Bar 5 10-04-2004 05:10 PM
12:37 PM
