95 5.0 Auto Smoking - HELP - Mustang Evolution
Old 06-01-2007, 06:37 PM   #1
chris7869's Avatar
Need advise b4 I take it in.
Yesterday a/c working fine, today, blowing out heat and causing the engine to smoke.
Coolent added ever week just about, but its a slow leak somwhere when driven daily. (if that might have anything to do with it).
All I can think is that maybe the heating core - but no leakage in the front passener (which was the case in an older Mustang a while ago)
Radiator has not cracked.
chris7869 is offline   Reply With Quote
Old 06-01-2007, 08:56 PM   #2
silverstangboy's Avatar
Re: 95 5.0 Auto Smoking - HELP
A/C will not cause engine to smoke. nor will a busted heater core, if the heater core is leaking the windows will easily fog and get worse if you turn on the defogger, your carpet will also usually be moist, or collecting coolant.
your slow coolant leak sounds like a blown head gasket, check tail pipes for white almost cloudy smoke and moister.. smell exhaust in a very detailed mannor, if it smell sweet/muggy then its a head gasket.
LUK!
93 mustang notch
~450hp 331 stroker - Sold
Old 06-02-2007, 03:51 AM   #3
chris7869's Avatar
Got it, thanks.
However, I'm curious why the smoking engine & the A/C to cause only heat to blow out at the same time. It's beyond me but it cant be a coincidence!
Trying to sell it, dont need this
Old 06-02-2007, 10:55 AM   #4
rocknbronco's Avatar
I would say the car was overheating.
rocknbronco is offline   Reply With Quote
Old 06-02-2007, 11:47 AM   #5
chris7869's Avatar
Overheating, definately! Just unsure on possible root causes. A blown head gasket sounds about right concerning the loss of coolant, but there are no "puddles" in my drive way, and still coolant disapears. Do you think its possible to loose only when driving?
p.s.: when the A/C is immediately turned off, it stops smoking! But when I turn it back on only heat is released instead of cold air.
appreciate any imput.
Old 06-03-2007, 02:55 PM   #6
bullitt482's Avatar
The reason there is no puddle, is because the car is "boiling" it and spitting it out the exhaust.
01 Bullitt
Old 06-03-2007, 03:03 PM   #7
X2
Old 06-24-2007, 04:04 PM   #8
OK..this is a really bizzare problem. First off..your AC has NOTHING to do with the engine. If your A/C blows hot...then either you lost the coolent or you compreser is shot....you blowing smoke...what kind of smoke...??? all the time???
IS this under normal driving?...just going down the road.....
your compressor will not turn on if you don't have the right amout of freon in it.
Your looseing coolent could be from the water pump..but could be from a head gasket.
If you had a gasket problem..it SHOULD show up all the time...not just when you turn on the A/C......
The really bizzare thing is if you turn on the A/C and your compressor( "DOSEN'T ) turn on...then there's no stress on the motor.....but for it to start to "smoke"....that's really bizzare.....
Need more info...
bobt is offline   Reply With Quote
Old 06-24-2007, 04:10 PM   #9
bbunt302's Avatar
The A/C can cause the motor to smoke. The compressor could seize up, causing the belt to have to slip over it instead of the pulley turning. If it "catches" and "releases" it could also cause all of your other belt driven accessories to do weird things (including the water pump).
Sounds like you have a seized compressor.
Scary stuff.
Old 06-24-2007, 05:03 PM   #10
well in that case the belt would be SCREEMING....which he did not say.
This some how, can be just a water pump type problem......and the water pump drops fuild on HOT parts..to create smoke????
This is all just a guess.... BUT if when turning on the A/C puts TOO much strain on the water pump......MAYBE it leakes.....and showes up as smoke......
this is just a wield guess....
Old 06-25-2007, 10:14 AM   #11
Herbstang's Avatar
Not in every case I had a A/C compresser seize up the belt slipped like a *****. But didn't scream
Old 06-25-2007, 05:32 PM   #12
bbunt302's Avatar
I had one do it too and the belt never "SCREEMING"'d once.
They can slip and catch and slip and catch and slip and catch and slip and catch and slip and catch and slip and catch and slip and catch and slip and catch and slip and catch and slip and catch and slip and catch without ever really "SCREEMING".
Scary stuff.
Old 06-25-2007, 05:33 PM   #13
bullitt482's Avatar
Yeah, it'd be more of a "fap fap fap fap fap fap" sound if you reallly really listened to it.
01 Bullitt
Old 06-26-2007, 08:31 AM   #14
Herbstang's Avatar
That's the sound
Old 01-14-2011, 01:06 AM   #15
94 Mustang GT's Avatar
If the compressor seizes the belt doesnt need to slip over it nor will it slip! The pulley is ALWAYS rotating, but on the inner side of the pulley is a magnet which engages when the a/c or defrost is commanded on! Nor would it cause the acc to do weird things!
But hopefully you got this issue figured out! lol
94 Mustang GT is offline   Reply With Quote
Old 01-14-2011, 12:32 PM   #16
MC770's Avatar
Check the dates before you comment, lol I've done this a couple of times too lol
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-14-2011, 08:28 PM   #17
I know they are old, I just like to look at some of the old ones comment on them and see what they ended up doing! lol
SMOKING------Chantix Tape The Bar 39 01-12-2011 11:13 PM
Smoking 99 Cobra 1996-2004 Mustang GT 4 09-18-2009 03:38 AM
Smoking 99 SVT Cobra 1996-2004 Mustang GT 14 08-04-2009 07:34 AM
smoking silverstangboy The Bar 64 08-13-2005 05:15 PM
So... I quit smoking... .:DarkEntity:. The Bar 27 08-07-2003 08:46 AM
11:51 PM
