New Toy... - Mustang Evolution
Old 06-20-2007, 04:06 PM   #1
bullitt482's Avatar
New Toy...
Comes with built in window switch for the nitrous kit, which allow me to spray from x rpm to x rpm which will save the motor if I EVER miss a shift. Has an automatic start ******, so when I'm running motor timing(16 degrees base) at 500 rpm and below it will ****** the timing so I won't have the "I want to turn over several several times before I crank" syndrome. I am also hooking up a 12 volt switch to the box that allows me to set a secondary rev limiter so I don't end up doing a 6,000 rpm burnout anymore(which is also adjustable on the box itself). I can readjust the other limiter that allows me to cut spark instead of fuel to set the revlimiter which will stop the loud pop during powershifting . The box also has a hookup to connect a MAP sensor in case the car ever becomes boosted and will adjust timing according to boost. Hell of a deal for a box that's only 10 bucks more than an MSD 6AL. The only thing is I ordered the 30 dollar harness so that if I ever want to go back to stock ingnition(heaven forbid) I can, since I didn't have to hack up the factory harness to the coil. Good stuff. Took about an hour to install yesterday.
The only part that sucks is that for the window switch, I can only use a 10 amp connection, since the box acts as a ground to complete the circuit on the solenoids. Thing is, Nitrous Works said that their solenoids discharge 11 amps after the solenoid....
01 Bullitt
Old 06-20-2007, 10:04 PM   #2
bluemustang's Avatar
Re: New Toy...
yup daddy needs to buy one of those when i go boost
my new toy Kyle Pictures and Videos 45 06-04-2008 10:02 PM
My new toy... USMCSS Pictures and Videos 17 10-31-2006 06:45 PM
My New Toy PJB Pictures and Videos 6 08-28-2006 09:44 PM
I got a new toy Tbird232ci Pictures and Videos 7 08-27-2006 09:43 AM
new toy... Fishers Stang The Bar 13 08-05-2006 03:43 PM
01:41 AM
