Originally Posted by bobt I'm redueing my 94 GT....from top to bottom. I do have a few questions that maybe you people can help me with.
First I want to upgrade to Corbra brakes. Ford Racing has the upgrade package which they list as M-2300-Q.. they seem to want to sell me the Master Cylinder..which looks like whats on the car to begin with.
This dosen't make alot of sence to me unless this M/C is completely different somehow. Do I really need this, or can I use the M/C thats on the car now? |
Yes, you need the master cylinder. The stock fox one won't cut it with the 4-wheel disc brakes.
Originally Posted by bobt Next question has to do with a crate engine. The car has 180K and still runs good....but it is tired...
I was looking at the Ford 345hp GT-40..this is basically a drop in replacement, and by all accounts should be an easy swap.
I have read thru all the postings on this sight before posting this....there is one post that says these motors don't put out anywere near this power..and also use the Hyper pistons.
I'm not sure why Ford racing would tell there Mustang owners that HP rating if they really can't get it???
Yes it does have the Hyper pistons...but isn't that what came in the stock 94 GT anyway?????
Yes it would be nice to have Forged pistons....but the price is right for this motor..about $3800.
I don't want to go nuts with a motor..it's a daily driver....I just want to keep up with the new 300hp GT's that are on the road now...(well OK..I'd like to beat them..LOL) |
I wouldn't buy the crate motor personally. You can build a much nicer motor for cheaper. You could get a set of AFR heads ($1300), an intake ($500) and a cam ($325 for a custom) that will blow that engine out of the water. With the remaining $1675, you can rebuild the bottom end and get all of the supporting parts (MAF, TB, injectors) to support the extra power.
Originally Posted by bobt I have the stock 8.8 rear with probably the 2.73 gears..not that 3.08 is alot quicker to begin with. By the way..this is the stock 5 speed.
I may consider going with a 3.7 rear gear....but the way gas prices are...LOL
Even with the stock engine and 2.7 gears....around town gas mileage is not great. Highway is good..if you can just cruse in 5th...
The Gas consumtion is not REALLY a major concern...but I'd hate to drop to like 10 MPG or something...LOL |
My H/C/I 5.0 gets around 22 mpg on the highway and 17 in the city. It makes right around 300 rwhp with the aforementioned AFR heads and has 3.73s. Get the 3.73s.
Originally Posted by bobt I "assume"..this crate engine will rev to 6K without any problems...I don't push my stock one past 5k anymore. |
Yes, thereabout. I usually shift mine at around 6k. It would pull longer, but I don't want to risk valve float, which is pretty easy to do with a hydraulic roller.
