what suspension are YOU running? - Mustang Evolution
Old 06-25-2007, 01:56 PM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
What kind of suspension are you running? what are some good combinations? progressive or specific spring rates? what kind of insulators are you using, stock or poly? i've heard that w/o using insulators the car dropps an additional 1/4in. but its all bad- due to vibration etc.
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 06-25-2007, 02:54 PM   #2
crazeflier07's Avatar
Send a message via AIM to crazeflier07
Re: what suspension are YOU running?
H&R Super Sport Springs, poly isolators front and rear (they do give you more drop without them but the ride can be harsher and noiser, metal to metal), Tokico HP blue shocks and struts, Steeda bumpsteer kit, and front strut tower bar. Gonna be getting MMs subframes, Steeda sway bars for front and rear and a rear tower brace next.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 06-25-2007, 04:29 PM   #3
bullitt482's Avatar
Southside UCA's and LCA's(going to ditch them for UPR's at some point), Eibach drag launch springs, Lakewood 50/50's and 70/30's, rubber isolators...
01 Bullitt
Old 06-25-2007, 05:24 PM   #4
bbunt302's Avatar
H&R Super Sport springs
Stock rubber isolators
Bilstein shocks & struts
Maximum Motorsports LCAs
MM Front Swaybar bushings & end links
MM C/C Plates
4-point cage and sub-frames
I like it.
Scary stuff.
Old 06-25-2007, 05:43 PM   #5
alright 2 HnR . 1 eibach.
bullit how r those drag launch on the streets?
ben hav u evr ran nething else beside billstiens? if u hav how do the billstiens compare? how much added wieght have u packed on?
ccplates are they easy to install?
keep em comming guys!
"Shake n bake"
Old 06-25-2007, 05:47 PM   #6
bullitt482's Avatar
The drag launches are great on the street, but I would never recommend them. The rates for the rear are different in an attempt to help with "even" planting of the tires......... Meh... Get your suspension done right with an antiroll bar for the rear... Just get you some good sport springs that don't slam the car for the back. The fronts do wonders though.
01 Bullitt
Old 06-25-2007, 07:38 PM   #7
Scut95's Avatar
Eibach prokit
stock rubber isolators
KYB AGX adjustable shocks
UPR caster camber plates
Stock strut tower brace
UPR Full length subframe connectors
(Coming soon- Bumpsteer kit, bigger sway bars, and UPR upper and lower control arms)
Old 06-25-2007, 07:52 PM   #8
bbunt302's Avatar
All I've had other than the Bilsteins is the stock shocks/struts, and there is no comparison there.
The C/C plates aren't bad. I'd go ahead and try to do springs, shocks/struts and C/C plates all at the same time if possible though. It will save you some headaches. Also, the easiest way by far to change the front springs on a fox is to drop the A-arms. You'll probably want two hydraulic jacks and a buddy to help though.
As for as weight, I've pretty much quit drinking so I'm actually starting to lose some right now.
If you meant the car... I have no idea. I think the extra weight added by the cage and subframes was probably canceled out by the aluminum heads and other lightweight parts.
Scary stuff.
Old 06-25-2007, 10:32 PM   #9
SilentNoise's Avatar
Send a message via MSN to SilentNoise
- H&R Super Sport springs
- Koni struts & shocks (single adjustable.... the red ones)
I absolutely love the ride and would recommend them to anyone with a daily driver
....And then I've got this stuff in the garage, but the car's gonna be up for sale this summer sometime so I'm not sure if I'm going to bother installing them:
- MM C/C plates
- MM full-length subframes
- Steeda 4500-series aluminum LCAs
Wolf Pack Car Club - Domestic V8 Performance Club (Edmonton, AB, Canada)
"If the automobile had followed the same development cycle as the computer, a Rolls-Royce would today cost $100, get a million miles per gallon, and explode once a year, killing everyone inside." -Robert X. Cringely
SilentNoise is offline   Reply With Quote
Old 06-25-2007, 11:29 PM   #10
SILENT: YOU'RE SELLING UR MUSTANG!? WHAT!!
BEN: foreal? you quit drinkin? holy crap, the world isss comming to an end.. haha jp
coils:
3 H & R 2 Eibach. O ford racing
shocks and struts:
koni 1 billstien 1 kyb 1 tokico 1 lake wood 1 (?)
i woulda thought that eibach n Ford Motorsport "B" springs (both having a 425-525lbs/inch progressive rate) woulda been top..
"Shake n bake"
Old 06-26-2007, 04:16 PM   #11
Going for something newer - maybe an 01-03 or something once I manage to sell my truck.
The 83 is fun to drive and all but it doesn't look as good as it does in pics. The car needs a bunch of bodywork and definitely needs paint (I joke that it's only got colored metal at this point). The engine's still mostly stock but it's creeping up on 190,000km (118,060 miles..... which is very impressive for an 83), and even though it's got quite a bit of blow-by, it still pulls pretty strong for a stock 175hp, 83 5.0L. If I was to try making any kind of power with the car, the engine would have to either be replaced or rebuilt. When it all comes down to it, I wouldn't mind keeping it, the biggest factor is that with only my little single-car garage available to me, I just don't have to space to work on it.... plus combine that with the fact that I'd just like to move into something newer, and she'll be up for sale this summer after I get a new toy.
Old 06-26-2007, 05:03 PM   #12
MonteCitan's Avatar
stock springs and struts... maximum motorsports upper/lower rear control arms, MM swaybars.. and some brand suspension bushings up front.. all poly..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-27-2007, 06:58 AM   #13
silverstangboy's Avatar
good job man, good luck and stick with it!!!
93 mustang notch
~450hp 331 stroker - Sold
Old 06-27-2007, 09:22 AM   #14
Zim
You want to **** me?
Zim's Avatar
H&R supersports here
no isolators
tokico shocks/struts
MM c/c plates
I like it, its not really that harsh without the iso's in, and handles great.
I like toys
what should i be running? tigercrazy718 General Mustang Discussion 0 05-19-2010 02:31 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
We got them running now Brent The Bar 7 02-14-2007 06:46 AM
No more running from cops in OK PureVenom The Bar 15 07-01-2006 04:46 PM
Running the V-6 05STANG Pre-2005 V6 Mustang 5 02-13-2006 07:36 AM
11:45 AM
