no fuel - Mustang Evolution
Old 06-30-2007, 02:55 PM   #1
no fuel
My first injected build, don't get fuel to injectors. build a 347 changed to 24lb
inj. 70mm throttle body 76 c&l mas, I have fuel to lines,but will not start. It is firing. pulled plugs, no fuel on them. any suggestons?
bulldawg4469 is offline   Reply With Quote
Old 06-30-2007, 11:55 PM   #2
Re: no fuel
Is your pump running?
Is it leaking gas anywhere?
Are you pulling a vacuum on the gas line through a pinhole?
Old 07-01-2007, 06:38 AM   #3
Re: no fuel
pump is running.
no leaks.
I have fuel at rail
Old 07-01-2007, 03:36 PM   #4
bullitt482's Avatar
Re: no fuel
Not getting pulses from the computer. I'd check your wiring.
01 Bullitt
Old 07-01-2007, 04:37 PM   #5
Kiljosh's Avatar
Re: no fuel
Ditto
If you have fuel in the lines they are either ALL clogged, highly unlikely. Or they just arent working.
Old 07-01-2007, 05:50 PM   #6
silverstangboy's Avatar
Re: no fuel
yeppers, exactly right. computer not calling for injector load. never hurts to have a FP gauge either.
this should help
http://www.veryuseful.com/mustang/te...ng_Diagram.gif
93 mustang notch
~450hp 331 stroker - Sold
Old 07-01-2007, 06:19 PM   #7
Joel5.0's Avatar
Re: no fuel
Follow the steps in this How to Solve an EFI No Start write-up.
1986 Mustang GT w/T-Tops :angryfire
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66 Small Port Heads, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears, LS Overhaul, Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), New Valve Springs (FRPP, done), Subframe Connectors (MM), Caster/Camber Plates (MM), T-Top weatherstriping and rear braces bodywork :cussing:
Joel5.0 is offline   Reply With Quote
Old 07-01-2007, 07:49 PM   #8
Re: no fuel
I checked wires on inj. are getting power, unplugged salt and pepper plugs and cleaned repluged, same. used starting fluid and it started, have stock fuel
reg., should I replace with adjustable, higher pressure one?
Old 07-04-2007, 11:59 AM   #9
MonteCitan's Avatar
Re: no fuel
I have a stock fuel regulator on my 331 with 24# injectors.. But I have it chipped, so it gives good fuel pressure.. my stock PCM had me running very lean at idle and somewhat lean at full throttle.. I had an adjustable one but it started leaking gas through it...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-06-2007, 05:56 PM   #10
Re: no fuel
Joel! had no idea you had mosied over this way before.
what do you think of ME? hopefully I haven't been giving out too much bad advice!
93 mustang notch
Old 07-09-2007, 09:15 AM   #11
Titus Wadicus
svtlx's Avatar
Re: no fuel
definatley no injector pulse....check your pcm, hot wires, and check to make sure you have sufficient ground. either your pcm is bad, or it doesn't know that it is on...just my opinion....and a hot injector wire doesn't mean anything if u don't get a pulse. i had a poor ground that started that problem for me, which ended up frying my a9l. is your car a efi convertion? if it is ground pin#'s 20-40-&60 straight to the ecu to the body. just a suggeston, not sure if that's your problem.
Old 07-09-2007, 04:02 PM   #12
bullitt482's Avatar
Re: no fuel
You missed something
01 Bullitt
Old 07-26-2007, 05:35 PM   #13
Re: no fuel
thanks for input, finaily got around to working on car again, turned out to be injectors, put different ones in and started!!
Old 07-30-2007, 10:57 AM   #14
Titus Wadicus
svtlx's Avatar
Re: no fuel
2: Huh? wut injectors did u have in it? i'm real curious.
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 04:32 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 04:22 PM
Not getting Fuel!!! Blt4dtuff 1979-1995 Mustang GT 5 05-29-2008 04:43 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-12-2005 12:04 AM
Fuel.. etc. Laser02 Pre-2005 V6 Mustang 3 11-16-2004 10:10 PM
04:31 AM
