Cobra Intake Problem - Mustang Evolution
Old 10-22-2010, 02:44 PM   #1
I just installed a new upper and lower Cobra Intake. There is a very loud whistle noise when the car is running. When I increase the idle the sound goes away. I am assuming this is a vaccume leak. I checked all of the vaccum lines and they seem to be fine. Does anyone have any suggestions and is there a trick to finding this leak if that is what it is?
kalvanjp is offline   Reply With Quote
Old 10-22-2010, 10:07 PM   #2
Re: Cobra Intake Problem
The only trick I know of is spraying starting fluid around the gasket surface if the car changes idle or revs up or stalls you know it has a leak. Other than that you can use a mechanics stethoscope to here where the sound is coming from.
Straublittleman is offline   Reply With Quote
Old 10-25-2010, 07:07 PM   #3
silverstangboy's Avatar
sometimes you will have a whistle noise that is normal depending on whether or not you replaced the throttle body or cold air intake with an aftermarket version.
I couldn't say which brands but I have heard alot of complaints some TB's making a loud noise
My cold air intake at times "moans" going down the road.
My wife's focus cold air makes alot of drive noise that sometimes "whistles"
93 mustang notch
~450hp 331 stroker - Sold
Old 10-26-2010, 07:30 AM   #4
banzaibullitt's Avatar
I haven't heard of the "TB whistling problem" before, but that may be it. I have a '96 Plymouth Voyager that has a whistling sound at highway cruising speeds. I wonder if it would be really loud if I removed the air silencer box on the intake?
banzaibullitt is offline   Reply With Quote
Erratic Idle problem solved-Intake manifold vacuum leak Mercedez L. 1979-1995 Mustang GT 7 07-30-2010 09:08 AM
cobra upper intake install vaccum lines problem trickflow211 1979-1995 Mustang GT 3 04-04-2009 08:27 AM
cobra intake swap 95stang_gt 1979-1995 Mustang GT 14 07-22-2008 05:40 PM
93 cobra intake Jay Rod 5.0 1979-1995 Mustang GT 29 11-21-2006 02:20 PM
02:29 PM
