my fox won't start - Mustang Evolution
Old 11-19-2010, 12:58 PM   #1
A.K.A. Baby-D!
my fox won't start
hey guys. yep, having problems with the fox too. but she won't even start
won't turn over... nothing. only get a 'click' when i turn the key. we've changed the starter solenoid, tested the battery, tested the alternator, and tested the starter. i had been having a problem with my bolts backing out from the starter from all the vibration of the engine, but i resolved that problem and the bolts are still there. except for the fact that one of the heads of a bolt broke off.. bolt is still stuck in there. i'm thinking it could be the wires going to the starter but not sure yet.
any other ideas?
EDIT: also wanted to ask, could it be something with my ignition switch?
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 11-19-2010, 04:44 PM   #2
Re: my fox won't start
Check your ground going from the battery to the engine block. I had a bad spot on the one on the 90 and it caused the same issues. 15 bucks will get you both power and ground lines just to ensure that's not the issue.
Old 11-19-2010, 05:04 PM   #3
A.K.A. Baby-D!
Thx man. I'll have to check that out. Makes perfect sense. Guess sometimes you look over the small stuff. Lol
Current:
Previous:
Old 11-19-2010, 10:56 PM   #4
04DSGM1's Avatar
Have u checked the leads to the starter yet?
2004 Dark Shadow Gray Metallic Mach 1
K&N Air Intake
04DSGM1 is offline   Reply With Quote
Old 11-20-2010, 03:07 AM   #5
GUDNEVL's Avatar
mine was the ignition switch,electric and mechanical,with same symptoms of urs
1989 mustang gt,short headers,3.08 gears,off road h pipe,flows,cold air intake,smog pump delete,fresh tune up,push button start,gt fog light fix ,everything else pretty much stock
most recent mod:blown head gasket
GUDNEVL is offline   Reply With Quote
Old 11-21-2010, 06:01 PM   #6
A.K.A. Baby-D!
Thx! Good to know.
And Shane I still need to check those wires as well. I'll be looking at the ignition switch if the wires check out ok.
Current:
Previous:
Old 11-21-2010, 06:45 PM   #7
Check the ground and connections on your voltage regulator. If its grounded to the metal fender it may have come loose from the vibration.
KMP90GT is offline   Reply With Quote
Old 11-21-2010, 10:53 PM   #8
GUDNEVL's Avatar
Originally Posted by 04TRV6 View Post
Thx! Good to know.
sorry ,i didn't read it good enough,my bad ignition didn't cause my starter bolts to break/loosen,lol.But it did all the clicking and stuff
Old 11-22-2010, 06:56 AM   #9
A.K.A. Baby-D!
lol i hadn't taken it that way..
Current:
Previous:
Old 11-22-2010, 06:56 AM   #10
A.K.A. Baby-D!
will check there too! thanks!
Current:
Previous:
Old 11-22-2010, 08:12 PM   #11
What's the verdict pony back to life yet or no?
Old 11-23-2010, 07:09 AM   #12
A.K.A. Baby-D!
the fox is parked at my moms at the moment hadn't been over there yet to check it out.
Current:
Previous:
Old 11-23-2010, 07:06 PM   #13
Ok well keep us posted I wanna kno what it was.
Old 11-29-2010, 11:15 AM   #14
A.K.A. Baby-D!
still haven't had a chance to look at what you guys advised, but i think i may have found the problem. hopefully taking a look at it this weekend if my plans fall together.
i found a water leak from my driver door which is leaking behind the driver seat on the floorboard. from what i'm told there is a harness running there. so i'm thinking that is the culprit. gonna be even more fun than i expected...
Current:
Previous:
Old 11-29-2010, 05:32 PM   #15
Do you have a digital multimeter? This tool makes trouble shooting so easy if you can get your hands on the wiring diagrams. Good luck
Old 12-01-2010, 03:06 PM   #16
A.K.A. Baby-D!
Yes I do. Thx for the tip!
Current:
Previous:
Old 12-01-2010, 03:15 PM   #17
Wiring diagrams are on alldata.com
Old 12-01-2010, 03:16 PM   #18
A.K.A. Baby-D!
awesome.. you've been a great help!
Current:
Previous:
Old 12-31-2010, 12:29 PM   #19
A.K.A. Baby-D!
Well guys I finally got the fox moved over to a better place. Safe from rain and easier to work on. Hoping to work on her this weekend. Just wanted to give the thread a bump & see if there are any other ideas before I start wrenching.
One small update. We did push start the car successfully to get it moved. So she does run. Just not start by key. Which was a relief for me and it felt GREAT to drive her again!
Current:
Previous:
Old 01-01-2011, 07:58 AM   #20
A.K.A. Baby-D!
Had a little spare time yesterday to look at the fox. When I turn the key I get a click noise from where my starter solenoid and msd are located. Found a circuit breaker but not sure where the wire was leading to, it goes into the firewall. Changed the circuit breaker just to be sure and nothing changed. As for the starter solenoid, we changed it the day that my car didn't want to start and that didn't change anything so I'm pretty sure that isn't an issue being brand new.
From what I could tell the click is meaning that I'm getting power up to that point??? And possibly not getting a good connection to the starter? We got under the car and tapped on the starter a bit which also didn't help. A friend of mine did notice a loose connection on the smaller black wire, which I'm thinking could be the problem. Gonna try to mess with that more and possibly put a fresh connector to eliminate that possibility. Also rechecked all fuses and everything was good.
I'm really thinking it's something very minor. It's just to find that needle in the haystack.
My question: does the fact that I'm getting that click sound mean that the ignition switch is in fact working? Still haven't eliminated that possibility if the starter wire doesn't fix anything.
Thx guys.
Current:
Previous:
Old 01-01-2011, 03:45 PM   #21
First thing I would do is put the car in neutral with the brake on or in park if u have an auto transmission.
Second, unplug the red wire with the blue stripe on your solenoid, turn the ignition key to the run position, and try to start it using a screw driver by jumping the + to the small post where red wire blue stripe came from.
If that works, it is either the ignition switch, loose wires on the plug that plugs into the ignition switch, or neutral safety switch.
FYI - even though the solenoid is new it could still be bad especially if you over torqued the nuts that hold the wires on.
Cobracoupe5 is offline   Reply With Quote
Old 01-01-2011, 04:08 PM   #22
A.K.A. Baby-D!
I dont have a wire that is red with blue stripe. The car has a lot of aftermarket goodies and the wiring is a mess thanks to the PO.
Current:
Previous:
Old 01-01-2011, 04:30 PM   #23
Murph's Avatar
Region: Maine
The clicking is symptomatic of some juice getting to the starter, but not enough to turn the engine over. Typical of a weak battery, bad battery cable connections (corrosion, etc.), or a bad block to chassis ground.
I'd start simple. Pull the cables off of the battery and take a wire brush to the clamps and battery post. Use a little WD40 and wipe them all down to clean off all the dust and crap. Reattach and make sure the clamps are tight enough that you can't spin them on the posts - no more.
I'd also question the battery itself. Ya, the voltmeter might show 12vdc, but the amperage is what's needed to spin the crank - a weak battery means not much amperage output. Most shops have load testers that will stress your battery to determine its cranking capacity.
The last place I would look at before deep diving into the electrical is the ground strap from the block to the chassis. Is it's frayed or you see a lot of corrosion on either end, that will definitely choke off the power from cranking the mill. Easy inspection to check over.
These are all easy things to check that usually account for 95% of the failures that lead to the "clicking" when trying to start an engine. I can personally attest to having had all of them bite me at one time or another over the years with various rides I have had.
One other question - can you jump (not bump) start it? If so, this will even raise the odds that it could be one of these 3 things.
Edited to add: I once had a loose nut (other than me) on the starter strand me one night until I got my hands on a screwdriver - which I still have but its a little burnt.
Murph's Glassback!
Murph is offline   Reply With Quote
Old 01-01-2011, 08:20 PM   #24
A.K.A. Baby-D!
Just fixed the starter bolt issue. They were backing out from vibrations but I have lock washers on it now and haven't had a problem with that since. Gonna be looking at it further tomorrow. Will check battery and ground as advised. Thx a lot
Current:
Previous:
Old 01-02-2011, 10:36 AM   #25
A.K.A. Baby-D!
Did not work jumping battery. Will be jacking up the car later and I'll check ground.
Current:
Previous:
Old 01-02-2011, 05:58 PM   #26
A.K.A. Baby-D!
She's alive needed a new starter.
Current:
Previous:
Old 01-02-2011, 07:17 PM   #27
Murph's Avatar
Region: Maine
Good news!
Murph's Glassback!
Old 01-02-2011, 08:24 PM   #28
Awsome! How much did the starter run you?
Old 01-03-2011, 06:59 AM   #29
GUDNEVL's Avatar
i think our cars are close kin,mine was doin the same thing as yours yet again,(clicking at the solenoid),wouldn't even jump start with cables,i put in a new battery and it fired right up,wierd
Old 01-03-2011, 09:36 AM   #30
A.K.A. Baby-D!
$120 new with lifetime warranty, $50 reman with 1 yr. Went with brand new.
Current:
Previous:
Old 01-03-2011, 09:37 AM   #31
A.K.A. Baby-D!
That is pretty weird. Always more than one way to skin a cat. Lol
Current:
Previous:
94 v6 - VS - Fox 5.0 sledgehammer Pre-2005 V6 Mustang 1 03-04-2008 05:44 PM
Someone with a fox.... fast64 Mustang Wheels & Tires 1 12-26-2007 09:00 PM
T-56 for fox? Can'tCatchMe 1979-1995 Mustang GT 13 01-30-2006 10:14 AM
Might be getting another fox soon.. MonteCitan The Bar 29 04-14-2005 10:19 PM
What ya think of this Fox? lowflyn The Bar 29 01-22-2005 10:50 PM
04:27 AM
