95 GT Speedo - Mustang Evolution
Old 12-05-2010, 08:59 PM   #1
95 GT Speedo
I just purchased a 95 GT and the speedo is reading fast by about 5 miles an hour. Anyone have the same problem? What would fix this?
95GT is offline   Reply With Quote
Old 12-05-2010, 09:14 PM   #2
MonteCitan's Avatar
Re: 95 GT Speedo
Well reading fast is better than reading slow (less risk of a ticket!)
How do you know its off? Have you tried comparing RPM to speed? (There are calculators online where you put in the final drive ratio, the trans ratio for the specific gear and the size of the wheels/tires and can get speed from RPM or vice versa)
Could be a few things throwing it off, incorrect speedo gear in trans, different gear ratio, different wheel size..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-05-2010, 09:26 PM   #3
Re: 95 GT Speedo
I use my GPS. It reads in my deville perfect and before I did I was getting passed by every car on the road. It seems to be off more the slower I go. Sometimes I go down my gravel drive and it dosent even move the needle until im going about 20mph or so. My tires and wheels match stock specs. I heard of gear going out on odometer but nothing about speedometer.
Old 12-06-2010, 12:24 PM   #4
Gster's Avatar
Previous owner probably put different gears in the rear, get a bigger speedo gear for your transmission.
Gster is offline   Reply With Quote
Old 12-06-2010, 01:43 PM   #5
Re: 95 GT Speedo
speedo gears just plug into the trans (has different number of teeth) but its not always 100% fix. You can figure out based on your rear ratio in 4th gear (1:1 gear) what rpm you are at at X mph and calculate your final drive to determine what gear you need.
You probably have 3.73 or 3.27s vs stock 2.08s or 2.73s~
Old 12-06-2010, 01:59 PM   #6
Im running less then 2000 rpms at 55 mph in fifth. I figure its stock gearing. Car was owned by a farmer and his daughter drove it while in college. Had 96,000 miles when I got it
speedo off k28gt 1996-2004 Mustang GT 19 11-27-2009 02:42 PM
Speedo is off... redbird2289 1996-2004 Mustang GT 14 09-10-2009 08:51 AM
speedo off electricstang99 Mustang Audio & Video 10 06-17-2005 02:39 PM
speedo jimmy_beaner Mustang Parts for Sale and Wanted 2 05-13-2005 07:21 PM
I need a speedo jimmy_beaner Mustang Parts for Sale and Wanted 4 05-13-2005 07:21 PM
06:26 PM
