Chip? - Mustang Evolution
Old 12-05-2010, 10:30 PM   #1
Chip?
Is it worth the money to get a high performance chip installed on my 95 Mustang GT? Also what gear ratio would be best? And who installs gears around springfield mo?
95GT is offline   Reply With Quote
Old 12-06-2010, 07:19 AM   #2
Re: Chip?
instead of a chip buy a hand held tuner, I am not sure which all work for the 94/95 computer as its not as easy to tune those but... I would not buy a chip as a hand held if one can be used for your car would be better (easier to modify tunes etc)
Old 12-06-2010, 10:15 AM   #3
Re: Chip?
You can't use a hand held tuner on the 94-95 gt's they're obd1. the v6's had obd2
Straublittleman is offline   Reply With Quote
Old 12-06-2010, 01:22 PM   #4
Re: Chip?
Gear.... In my old 95 I had 355 but I had always wished they were 373..
So I would say 373...
zztop1234 is offline   Reply With Quote
Old 12-06-2010, 01:57 PM   #5
Re: Chip?
I thought someone had developed some sort of tuner that would work? Not sure how it works though.
Old 12-06-2010, 05:44 PM   #6
What's the top speed with 3:73 gears?
Old 12-06-2010, 06:01 PM   #7
Re: Chip?
Fast enough
Old 12-07-2010, 09:13 AM   #8
Re: Chip?
yea 3.73s will do enough as long as its not rpm limited~ which on my 97 v6 made me stop at 85 mph lol...
Old 12-07-2010, 04:51 PM   #9
sick04mustang's Avatar
Chips r ok but work best with mods to help boost performance. Other wise they have little effect. Also if u drive every day 3.73 will wake it up a good bit 4.10 is a gas hog
04GT(BRANDI) VORTECH S/C,PATRIOT STAGE2 HEADS,ANDERSON POWERPIPE,SUPERCHIP,36IB INJECTORS,4.10, C&L INTAKE,ACCUFAB THROTTLEBODY, 1/2INCH INTAKE SPACER,EIBACH PRO SPRINGS,H.O.FIBERTRENDS 4INCH HOOD
sick04mustang is offline   Reply With Quote
Old 12-07-2010, 08:29 PM   #10
Well a old friend runs a speed shop and said he might have one for free. I haven't talked to him yet just threw a mutual friend and wanted some honest opinions.
Old 12-07-2010, 08:32 PM   #11
Re: Chip?
If you can get it cheap go for it! That way if you decide to put a turbo/supercharger or nos on it you will be half way setup for it.
Old 12-08-2010, 07:44 PM   #12
Titus Wadicus
svtlx's Avatar
Re: Chip?
they got hanheld tuners for obd1 now? was i napn that long? wtf! and this whole time i was twist'n on the distributor...lol.
Old 12-13-2010, 10:00 PM   #13
silverstangboy's Avatar
Re: Chip?
I don't think so, I understand that PMS is easy to tune but its still a lappy deal.
Personally I ended up being really unhappy with my tweecer... I like working on the car (turning wrench type work) tuning this thing reminds me of being AT WORK.
im probably going to sell it soon and get a chip.
93 mustang notch
~450hp 331 stroker - Sold
Old 12-14-2010, 08:46 PM   #14
Titus Wadicus
svtlx's Avatar
Re: Chip?
did it increase ur hp?
Old 12-14-2010, 09:34 PM   #15
Blustreek's Avatar
Region: Hawaii
Re: Chip?
Hey 95GT go to (americanmuscle.com)and click on tuners.Under ur application will list a flashchip to put in place of ur stock P.R.O.M. (Programmable Read Only Memory)chip from a company called SCT,I believe it has multiple mode flash programs on the one chip that is controlled by a selector switch you install in place of ur GT's cigarette lighter element. Check it bud! O! I believe also that
if you go that route and need installation instructions AM has
them step by step on their website as well under tech intsall.
Blustreek is offline   Reply With Quote
Old 12-15-2010, 09:09 PM   #16
Don't waste ur money on a chip or tuner unless u have a lot of work done to the car already! Like cam, heads, grs, upper and lower intake, headres and full exhaust, full ignetion system... I wasted $250 on a chip even after I had so much done to my car like 2yrs back the dam thing didn't make any different. Now if u have a turbo, s/c, or nos that's a different story and u def need a tune for that. For grs I woukd def go with 373 for daily drive
5lturbo is offline   Reply With Quote
Old 12-16-2010, 09:35 PM   #17
Re: Chip?
Good to talk to you again dude
but to answer your question I couldn't say, my car is running such "strange" mods that the car won't run without the tune so I have really nothing to compare it too... but I have been VERY conservative on the timing in that car just in case something goes nil at high RPM and 10.6:1 compression
soo... I think a professional tune would net better performance if for that reason alone
93 mustang notch
Old 12-18-2010, 10:42 AM   #18
Titus Wadicus
svtlx's Avatar
Re: Chip?
good to talk to u too. i was just curious. i haven't felt it would help me out with my set-up at this point. and run'n under 14psi of boost on stock heads, it just doesnt seem necessary.
Do you need a chip? snydermj 2005-2010 Mustang GT 16 09-11-2009 06:54 PM
Chip Gray Ghost 1996-2004 Mustang GT 6 04-02-2009 09:04 AM
chip Sublime782 Pre-2005 V6 Mustang 11 06-09-2005 02:32 AM
f2 chip ttpancakes Pre-2005 V6 Mustang 3 07-07-2004 10:46 AM
Chip ERICK Pre-2005 V6 Mustang 2 08-08-2003 05:50 AM
03:33 AM
