grinding in third?? - Mustang Evolution
Old 07-10-2007, 10:38 AM   #1
bluestang1724's Avatar
grinding in third??
i cant figure out why but my car keeps grinding when i shift into third gear. it only does it when the rpms get high when i shift. if i wait for the rpms to drop then shift its fine.
car: 2000 v6 5-speed
1995 cobra svt
bluestang1724 is offline   Reply With Quote
Old 07-10-2007, 12:12 PM   #2
Re: grinding in third??
change the fluid as of late?
could just be a syncro going out.
Old 07-11-2007, 04:57 PM   #3
bullitt482's Avatar
/\ What he said. Sounds like the synros are starting to give way.
01 Bullitt
Old 07-11-2007, 08:58 PM   #4
Zim
You want to **** me?
Zim's Avatar
do you have a firewall adjuster or adjustable clutch cable on it? Those tend to stretch out and you may need to do some adjusting. Also, if you still have the stock clutch quadrant, try pulling out on the clutch pedal and see if it adjusts it at all. Mine used to do that, and it just took some adjustment at the firewall to get it back in check.
I like toys
Old 07-11-2007, 11:32 PM   #5
it has a firewall adjuster and i adjusted it but i still feels the same no matter what i do. maybe its just stretched out or something
1995 cobra svt
Old 07-12-2007, 10:08 PM   #6
Zim
Zim's Avatar
what clutch cable is on it? if its stock and has over 50k miles, ill almost guarantee its stretched out
I like toys
Old 07-13-2007, 07:08 AM   #7
If you adjusted your clutch so the clutch petal is as far out as it can go (aka it is actually hitting the bump stop for the clutch petal travel) and the cable has tension on it that you feel when you touch the petal (aka not flopping) then you should have enough travel. You can take the dust cover off on the drivers side of the tranny really easy and watch it pull the clutch fork in/out to be sure if you want~
If that doesnt fix it then it sound like 3rd is just going out
Old 11-29-2007, 10:44 PM   #8
there is one more thing it could be, it can also possibly be the pilot bearing i had a grinding problem with my car too one time. thought it was the transmission but when changed the clutch, pressure plate and pilot bearing all the grinding went away. but if its just third then idk. its the cheapest and esiest thing to check first.
blackmustang95 is offline   Reply With Quote
Old 11-30-2007, 01:57 AM   #9
well im changing the tranny this weekend, b/c that thing is gone to hell!! there's a crack in the side of it and its hard to shift into all the gears and sometimes it grinds in second now too. i bought a brand new tremec cobra r tranny from summitracing.com
1995 cobra svt
Old 02-10-2008, 06:16 PM   #10
let uknow how that tranny works for you.i am about to go the same way.
mustangmaddness is offline   Reply With Quote
Grinding into 3rd gear tedness 1996-2004 Mustang GT 9 01-19-2010 06:32 AM
grinding sound elystarz New Member Introductions & Greetings 1 08-15-2009 06:57 PM
Grinding Noise From Gears parkerr1 General Mustang Discussion 5 12-16-2008 05:34 PM
Grinding in second BAgee87 1996-2004 Mustang GT 4 10-14-2008 09:05 AM
grinding from rear gt4me 1996-2004 Mustang GT 8 11-29-2004 10:36 PM
06:49 AM
