Correct speedo gear???? - Mustang Evolution
Old 12-20-2010, 04:14 PM   #1
Qwik Four Six's Avatar
I have a 1989 mustang coupe 4 cyl conversio with a t5 transmission. It has stock 4 cyl gauges. It has a 8.8 with 3.73 gears. What is the correct speedo gear I need for it? 19, 20, 21, 23 tooth?
Qwik Four Six is offline   Reply With Quote
Old 12-21-2010, 07:34 AM   #2
Re: Correct speedo gear????
there is no "correct" as far as making it 100% correct with 3.73 gears. Depending on the computer setup you have you may can do a dallas speedcal unit. It plugs in between the VSS sensor on the trans and the computer and alters the signal going to the computer from the trans. You leave the stock tooth gear in the trans and just flip some switches to calibrate it for any size tire and any gear ratio pretty much. If this wont work (best option since you cant do it in a tune) then you can run I think a 21 or 23... but it wont be accurate it will still be 5-7mph off (it gets worse as the MPH increases... you may be somewhat accurate at 55 but not at 15 or what not)
Old 01-17-2011, 02:25 AM   #3
Thanks. Don't really want a ticket because of it being inaccurate. Lol. Got a guy here in rock hill that has worked at a dealership and done many repairs on fords and he owns a few also. I'll see what he thinks about it. It's carbourated though. No computer.
Old 01-17-2011, 07:17 AM   #4
Site Sponsor
Sponsor
Steve@CJPony's Avatar
You have a 89 V8 with T5 and 3.73's you will need a 21 tooth.
MUSTANG SPEEDOMETER GEAR AUTOMATIC 21 TOOTH 1965-1998
Steve Riss | Forum Administrator
CJ Pony Parts, Inc.
1-800-888-6473 ext. 143
Facebook | Twitter | Google + | YouTube | CJ Blog
Steve@CJPony is offline   Reply With Quote
Old 01-17-2011, 07:19 AM   #5
Wow! Thanks. I'll probably be ordering one from you soon.
Old 01-17-2011, 07:21 AM   #6
an 89 may have a different output shaft speedo gear and different gearing, try the 21 tooth, but dont trust it. Get someone to help you test the speed to see. The only true way to fix it otherwise is to change the output shaft gear as well as the 21 tooth so they match up right
Old 01-17-2011, 07:23 AM   #7
Yea. Thanks. That's also what my dad was saying. How hard is it to replace the shaft?
Old 01-17-2011, 06:32 PM   #8
Automatic?
Old 01-18-2011, 07:03 AM   #9
Site Sponsor
Sponsor
Originally Posted by Blb97stang View Post
Automatic?
you would use the same speedo gear as posted above.
CJ Pony Parts, Inc.
Old 01-18-2011, 07:07 AM   #10
Oh. Okay. It said automatic and I wasn't sure.
Old 01-18-2011, 07:09 AM   #11
Site Sponsor
Sponsor
a lot of those gears work for a variety of applications.
CJ Pony Parts, Inc.
Old 01-18-2011, 07:10 AM   #12
Oh okay. Thanks.
Old 01-18-2011, 07:11 AM   #13
Site Sponsor
Sponsor
Oh okay. Thanks.
no problem
CJ Pony Parts, Inc.
Old 01-18-2011, 07:15 AM   #14
So $9.95 and free shipping?
Old 01-18-2011, 07:23 AM   #15
give a 21 tooth a try, if the speedo is not exactly right the shaft is not THAT hard to mess with so ive heard.
Old 01-18-2011, 07:25 AM   #16
Transmission shaft...
Old 01-18-2011, 07:27 AM   #17
Site Sponsor
Sponsor
That is correct.
CJ Pony Parts, Inc.
Old 01-18-2011, 07:27 AM   #18
That is correct.
Alright cool. Thanks. I'll be ordering one soon.
Old 01-18-2011, 07:54 AM   #19
I put a 21 and then a 23 tooth in my 97 with 3.73 up from 2.73s and it was 5-7mph off~ all the time the lower the speed the closer it was of course. The speedcal is the best way to go but its only for 94 up
Old 01-18-2011, 08:05 AM   #20
Oh. That sucks. Mines carbourated.
Old 01-18-2011, 10:13 AM   #21
WhiteCobra94's Avatar
What about a 94 AODE with 4.10s..... I'm right on till I get to 35mph I'm about 5mph off and once I hit 45-50 I'm a steady 10mph off , I'm use to it now when I drive it but gets annoying sometimes
Old 01-18-2011, 10:15 AM   #22
Site Sponsor
Sponsor
AOD SPEEDOMETER GEAR 23 Tooth | CJ Pony Parts
CJ Pony Parts, Inc.
Old 01-18-2011, 10:42 AM   #23
I believe 94+ can be used with the speedcal unit when a speedo tooth is not adaquate to fix. You need to reinstall the factory tooth speedo gear before using one though.
Old 01-18-2011, 10:44 AM   #24
Site Sponsor
Sponsor
Nope the speedo recal boxes are for 99-04
CJ Pony Parts, Inc.
Old 01-26-2011, 04:37 PM   #25
Well, I ordered a 21 tooth, got it today. Took the old one out and compared them and the old one is a 21 also. I don't know if y'all thought that I didn't have one at all or what. So, I put the new one in anyways. Didn't think it would work because nothing was wrong with the old one. And it still doesn't work. I know I could take the cluster out and see if the thing was atleast trying to turn the needle. Any ideas??
Old 01-27-2011, 06:22 AM   #26
Site Sponsor
Sponsor
Well for you application that is the gear you should need. Give our tech guys a shout and see what they have to say. You can reach them at tech@cjponyparts.com make sure you explain to them everything you have and what's going on. If anyone will have answers and solutions it will be those guys.
CJ Pony Parts, Inc.
Old 01-27-2011, 04:18 PM   #27
Alright thanks.
Old 01-27-2011, 09:52 PM   #28
Alright thanks.
World Class T5 Speedometer Gear. Which one do I need? - Ford Mustang Forums
Straublittleman is offline   Reply With Quote
Old 01-27-2011, 11:02 PM   #29
Thanks but, how does this help?
Old 01-27-2011, 11:02 PM   #30
Old 01-28-2011, 02:59 AM   #31
Well if you need help figuring out what gear you need then it tells you how to do it. My question is, is your speedo working at all if it isn't then you probably need a new dash cluster.
Old 01-28-2011, 05:34 AM   #32
Nope, neither does the stock tach, all other guages work, the mile counter doesn't work.
Old 01-28-2011, 10:36 PM   #33
Well the speedo only has a few things that can go wrong, 1st the cable, 2nd the speedo gear/or the gear in the tranny, 3rd the cluster itself. The tach is electrical and for it to work right must be a v8 cluster unless it has the switch you can turn that is usually at the top of the cluster itself near the tach side. My old 79 had the switch but I don't know if the newer ones had it.
Id say you most likely need a new cluster. But if you pull the speedo cable out of the tranny and spin the gear with your hand then the speedo should move. If it does then you need a gear in the tranny witch isn't hard to change. If it doesn't then you need a cable or a cluster.
Old 01-28-2011, 11:25 PM   #34
Didn't mean to sound bad or any thing when I asked how that helped. This helps though, I might get under it this weekend. Thanks.
Old 01-29-2011, 02:37 AM   #35
No problem just here to help the best I can.
Correct speedometer gear... 67mustang97 Pre-2005 V6 Mustang 8 08-13-2008 03:20 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
Speedo Gear Brent Pre-2005 V6 Mustang 15 06-23-2004 12:08 PM
Gears and tlok speedo correct Falcon Pre-2005 V6 Mustang 15 12-21-2003 06:54 PM
410 gear speedo question Freds3.8 Pre-2005 V6 Mustang 23 07-21-2003 02:07 PM
09:06 AM
