Rack and pinion?? - Mustang Evolution
Old 12-22-2010, 06:54 PM   #1
Rack and pinion??
I'm changing out th rack and pinion on my 88 Lx and unfortunately the car sat for the last 5 years!! The driverside mounting bolt was fused to the sleeve going through the k-member. The only way I could get it out was to cut it ( cutting through the sleeve also!) Where or what can I do to get a new sleeve??
Twic is offline   Reply With Quote
Old 12-22-2010, 11:57 PM   #2
Re: Rack and pinion??
Sleeve? meaning whats around the bolt? It should come with new bushings, if not you could call a junk yard and see how much they would want for one.
Straublittleman is offline   Reply With Quote
Old 12-23-2010, 05:33 AM   #3
Their is a sleeve in the k-member that the mounting bolts slide through. New bushings don't come with any hardware, just bushings! LRS has new mounting bolts, but nothing on the sleeve/ cylinder that is in the k-member! I've been to a bunch of salvage yards and only come across 1 foxbody, so hopefully I can find it!
Old 12-23-2010, 10:59 AM   #4
Sorry!! I'm a dumb- A, its the sleeve in the bushings! When I cut through it, part of it was wedged in the hole and looked like it went all the way through the k-member!!
Old 12-23-2010, 01:14 PM   #5
You might get lucky and find something at a hardware store or a tractor supply.
Old 12-23-2010, 01:23 PM   #6
I have new energy suspension bushings for the new rack and pinion, I just need to get a new rubber bushings for the sleeve inside the rubber bushings!! After I clean off 20 years of sludge off the k-member!
Old 12-24-2010, 11:25 AM   #7
ibleedblue65's Avatar
You are special. Lol
ibleedblue65 is offline   Reply With Quote
Old 12-25-2010, 12:33 AM   #8
rack&pinion for 65 ??? rwood53 Classic Mustangs 11 01-06-2011 06:15 PM
rack & pinion 04TRV6 Pre-2005 V6 Mustang 11 03-08-2010 07:14 PM
Rack and pinion Scut95 The Bar 0 05-11-2008 06:54 PM
Need New Rack-n-Pinion and Suspension... Whats best brand?? superstarjade 1996-2004 Mustang GT 0 03-13-2008 08:09 AM
Rack and pinion Ponycarman Pre-2005 V6 Mustang 13 06-17-2005 06:27 PM
07:09 AM
