Air Bag light = blown fuses and no turn signals???? - Mustang Evolution
Old 12-23-2010, 04:42 PM   #1
95GT5.0's Avatar
Send a message via AIM to 95GT5.0
OK so im new here and i thought somebody might have experienced the same odd problem i am having. So there are some light scratches on the left side of my rear bumper which tells me someone backed into it. When i got into the car the airbag light was on. So i figure there is a sensor in the rear that needs to be fixed. Wrong! Then the airbag fuze that connects to the turn signals and reverse lights keeps blowing out. I replaced them 10 times and the second i shift to reverse it pops again. So i have exhausted all ideas that I or my chiltons manual have been able to come up with. If anyone has an advice i would appreciate it.
1995 5.0 lots of mods.
95GT5.0 is offline   Reply With Quote
Old 12-29-2010, 05:25 PM   #2
Blustreek's Avatar
Region: Hawaii
Re: Air Bag light = blown fuses and no turn signals????
Well first of all,At the are where the hit and run happened
is the damage only to the bumper or any part of the quarter panel? Because if fuse is popping at the release of
reverse gear the shifter enables current to the reverse lamps.Look behind inner panel for wire harness being pinched somewhere there,what you have is a dead short.
If not check anywhere along that line,Remember the logic,
fuse shorts out when gear selector is engaged in reverse
so whatever receives power when reverse switch is on to ground that where the short will be.Check all ur bulbs too!
Go get the electrical schematics for rev-lmp.switch & multi-function switch & clock spring.
Blustreek is offline   Reply With Quote
air bag light blinking jcl2669 1979-1995 Mustang GT 10 01-13-2011 11:50 PM
Replacing turn signals ThaBear14 2005-2010 Mustang GT 15 12-09-2009 07:35 PM
Shutting off the air bag light? Otlaw80 1979-1995 Mustang GT 8 08-25-2009 12:06 PM
air bag light widowvirgin Pre-2005 V6 Mustang 7 07-19-2004 03:28 PM
Turn signals robert0803 Pre-2005 V6 Mustang 7 09-30-2003 10:52 PM
10:19 AM
