Coolant Leak? - Mustang Evolution
Old 12-27-2010, 04:02 PM   #1
BrKu789's Avatar
Send a message via AIM to BrKu789
Coolant Leak?
Hello again.
I recently asked how to replace a water pump. Well I got a closer look at it and it doesn't look like the water pump is leaking. It more just looks like it's coming out of the bottom of the engine block near where the pulley is.
What would be causing this? Or am I just completely wrong in thinking that it is not the water pump?
NEXT TO SEX, MY MUSTANG IS BEST
BrKu789 is offline   Reply With Quote
Old 12-27-2010, 04:54 PM   #2
BrKu789's Avatar
Re: Coolant Leak?
Here are the pictures of where I think the leak is. The first one has stuff I added. It is just a view from underneath the car. The highlighted area in the first one is where I believe the leak is coming from.
The second picture is just a picture without all my added stuff so maybe you can get a better look!
If you cant see the pictures the link to them is here!
http://s1086.photobucket.com/albums/...DLeak2copy.jpg
http://s1086.photobucket.com/albums/...rent=Leak2.jpg
Old 12-28-2010, 02:46 AM   #3
Re: Coolant Leak?
Take your pullies off and look to see if the hole is leaking there. If its not leaking there then its not your water pump.
Pic is only for reference.
Straublittleman is offline   Reply With Quote
Old 12-28-2010, 08:40 AM   #4
BrKu789's Avatar
Alright thanks! I will check it out!
bad coolant leak jmachleit 1979-1995 Mustang GT 8 01-13-2010 04:31 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 08:40 PM
coolant leak inside car Racin02GT 1996-2004 Mustang GT 8 06-19-2006 06:19 PM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
07:04 AM
