help wat cam to choose - Mustang Evolution
Old 12-29-2010, 04:46 PM   #1
Cool help wat cam to choose
i have a 351w on my fox body an my set up is..(75 block)..( motor .030 bore over)( 9:1 comp)( edL torker 2 manifold single plain)( 750 dp cfm summit carb)1"spacer(.bbk LTs)
torker plus cam 5082 cam specs(110 lsa*)duration 224/234) lift 496/520 power range 2500-6500
voodoo lunati 61004 cam specs(110 lsa)duration233/241) lift 538/560 power range 2200-6400
the torker cam is matched to run wit my manifold.but wat if i could get more power wit the voodoo cam an it is almost the same pwr range ...or do u guys kno another good cam that would be better my car is not gonna be a daly driver a weeken car ..drag racing only...thanks
juced302 is offline   Reply With Quote
Old 12-29-2010, 08:52 PM   #2
Blustreek's Avatar
Region: Hawaii
Re: help wat cam to choose
Looking at the numbers you posted of the two cam specs I'd go with the Lunati Voodoo camshaft. Better duration for torque and way more lift for higher compression plus ur powerband response is earlier,better holeshot power.
Goodluck dude w/ur project. My unofficial opinion.
Blustreek is offline   Reply With Quote
Old 12-31-2010, 08:30 AM   #3
WhiteCobra94's Avatar
Also make sure the cam you get matches the same power range as your heads , to get the most HP out of it! And easier to tune when the power range matches up!
wat do i need juced302 1979-1995 Mustang GT 13 02-19-2010 01:08 PM
a.o.d trans but wat torqe conveter juced302 1979-1995 Mustang GT 6 01-25-2010 12:34 AM
i have around $800...wat shall i get next? 98MustangGT 1996-2004 Mustang GT 12 07-20-2007 09:50 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
Wat size tire horess05 Mustang Wheels & Tires 2 05-21-2004 10:40 PM
01:30 AM
