fuel economy advice... - Mustang Evolution
Old 12-30-2010, 10:03 AM   #1
Titus Wadicus
svtlx's Avatar
ok. so i fell of my chair when i saw 3.15 a gallon. i like driving my stang on the street and would like to maybe take a road trip in it one day. however, the price of premium and race fuel (i mix it) have got me reluctant. here's my set-up
standard stroke 308 (.40 over)
mls head gaskets
hand ported e7
arp rod, head, studs, and intake bolts
bbk ssi intake w/ 1inch spacer
70ml t/b
90ml pro-m w/30lb. calibration..w/30lbs inj. 255lph fuel pump
e-cam w/1.7rr.... .560 comp valve springs
11psi boost
timing @ 10 degrees advance
msd 6a, msd coil, high dwell ignition control module
off road xpipe with mac mufflers
racing aod w/24-2700rpm stall
spherical upper trailing arm bushings
boxed upper and lower trailing arms
4cyl. front springs and anti-sway
v-8 "convertible" rear springs and sway bar
welded frame ties
7.5 3.42 gears w/traclok
my car is @ 24-2500rpm on the highway @ 65mph.... is this normal?
the gas milage is freak'n horrible!!! if i see 12mpg's (hghway) the light of jesus is shining upon my 5 liter. i have some 3.73 i was goin to install but it's a bit overkill. i wanna achieve a low rpm (highway)cruising speed for fuel milage, but still (if possible) be able to get out the hole. i just bought a 96 v-6 that has a 2.73. and swap all my v-8 stuff into it.
#1.....my plan...
install my traclok into the 2.73
up my boost to 14psi to make up for the lower gear...
i figured between the increase in boost and my stall speed, that i should still be able to get out the hole with the 2.73 .
as well as save a lil fuel with low rpm highway cruising speed.
(or keep boost the same)
#2.....the other plan...
purchase a used 96-98 gt rear end with 3.27 (i can pick-up for under $200)
but stock gt's are only rated for around 25mpg highway. however, i should still be able get out of the hole pretty good with the 3.27
fuel economy is my greater concern because of the price of gas, and race fule in my parts is around 6.50-6.75 a gallon (i usually need approx. to gall. for car to run smooth)
my question is this... which plan will net me the most highway milage? or is better fuel milage just a pipe dream and the nature of the beast because of my set-up. ('03 cobra rated for 21mpg's highway)
im just tryn to get sum thoughts and opinions from everyone. worse cums to worse, i will just swap my 3.42's into the 96. it's super torquey, and is the only car that i owned that could go sideways at 50mph (says alot from an auto). however, im willing to sacrifice sum torque to be able to afford to still drive the car on the weekends. (fuel prices are projected to hit $5.00gall by 2012). let me know wut u guys think....thanks.
Old 12-30-2010, 10:38 AM   #2
Re: fuel economy advice...
i would set it up so its fun to drive and if gas is to expensive then buy a DD and just drive it when its nice out to save money there.
if you drive at 55mph vs 65 etc and dont go high in the rpm between gears it should help tons as well
Old 12-30-2010, 10:54 AM   #3
Titus Wadicus
svtlx's Avatar
i got a dd. it's fun to drive now with the 3.42's, it's just expensive.
Old 12-30-2010, 11:22 PM   #4
ponyboy94's Avatar
my v6 runs up near 2400 on the highway at 65 but it runs lower at like 75 80
ponyboy94 is offline   Reply With Quote
Old 12-30-2010, 11:36 PM   #5
1ijack's Avatar
Send a message via Yahoo to 1ijack
I look at it this I did not buy a mustang with a v8 for fuel economy. I got it to blow the doors off other rivals from stoplight to stoplight or at the drag strip. Yes mine is a daily driver and I put 80 miles a day not including my run around miles.
I average about 23 miles to the gallon. So I can't complain just remember these could be the last of a dying breed. Older cars are getting harder to find.
I have done a lot to get my stang go where it Is now I have put vacuum gauges and air fuel gauges to keep me out of the throttle and worked on the fuel cell and pump. The biggest thing was the sct programmer that gave me better fuel economy.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 12-31-2010, 08:37 AM   #6
Titus Wadicus
svtlx's Avatar
sooo, your say'n that your rpms decrease the faster you go? do you have the 5spd w/2.73 gears?
Old 12-31-2010, 09:06 AM   #7
Titus Wadicus
svtlx's Avatar
23mpg really... ii'd fukn kill for that kinda milage, maybe not kill...but i'd hurt somebody pretty damn bad stop light to stop runs yield me single digit mpgs. beating somone at a stop light is more than pride for me, itsa finanacial commitment. if it ain't a vette, a bike, or something boosted, i dont waste my time/money. anyway, im suppose to b setting an example for others.
Old 01-01-2011, 07:21 PM   #8
Qwik Four Six's Avatar
Lol! That's what I got mine for! Damn imports
Qwik Four Six is offline   Reply With Quote
Old 01-01-2011, 10:04 PM   #9
ibleedblue65's Avatar
Your fuel mileage is extremely low for your setup. Either you drive everywhere with your foot matted or there is another issue. I would not worry about any solution except for the one that follows the diagnosis of your real problem.
ibleedblue65 is offline   Reply With Quote
Old 01-01-2011, 10:33 PM   #10
Titus Wadicus
svtlx's Avatar
oook, well wuts the real problem? the last part kinda sounded like a chinese riddle
Old 01-02-2011, 10:03 AM   #11
Are there any codes stored? What size injector are you running? When was the last time you cleaned your maf? What about the tune, when was it tuned last? When was the last time you had a wideband in it? Just trying to help out because something else is goin on here. My 65 carbureted coupe gets close to 19. I only have a3.27 in it now, but its still a500 horse car. You should be at 13 or so, possibly better.
Old 01-02-2011, 10:16 AM   #12
Titus Wadicus
svtlx's Avatar
re-read my set-up on top of thread. i posted everything you asked. it's a obd1 system.
Old 01-02-2011, 10:21 AM   #13
Titus Wadicus
svtlx's Avatar
my car is an auto. also, i live in the city, not rural. so i have to maintain 65mph on the highway. slower speed could cause an accident or cause me to get cited for "obstruction of traffic" "failure to maintain a safe speed". however, i do have a stall speed converter...possibly this is where my gas is goin.
Old 01-02-2011, 10:24 AM   #14
Titus Wadicus
svtlx's Avatar
9-13mpg is typical of what i see...im tryn to get high teens...maybe low twenties.
Old 01-02-2011, 11:15 AM   #15
You answered very few of those questions. I still think that number is low for your setup. You might consider just going to pump fuel. Clean the maf and make sure the tune is dead on.
Old 01-02-2011, 11:18 AM   #16
A stock five speed notch may get 19 or 20. Trying to get better than that in am auto car is going to be next to impossible but you should be able to average 13 or better depending on how you drive.
Old 01-02-2011, 11:52 AM   #17
Titus Wadicus
svtlx's Avatar
it's never had a wide band on it. the mass air is clean. the plugs are new. as far as doing anything to the pcm...it's stock. it's not really necessary on an obd1 car running under a full atmoshere/bar (less than 14psi). ive tried running 24lbs injectors, 26lbs...but it runs smoothly with 30's. i could possibly bump the timing up a bit, but im hesitant with 11psi. it's pretty snappy and there's no ping'n or pop'n.
im really start'n to think it's the stall converter. itsa 24- 2700 stall. it keeps the motor reved up more than a stock converter on regular driving. not to mention, my aod wont go into overdrive till i get 55mph or more.
How About That Economy? Brent The Bar 9 09-29-2008 09:23 PM
Fuel Economy fossen Pre-2005 V6 Mustang 4 04-11-2007 06:53 AM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
Fuel Economy hate_romania Pre-2005 V6 Mustang 14 07-08-2004 09:29 AM
The economy sucks Brent The Bar 0 03-21-2004 06:09 PM
12:52 PM
