Foxbody switching to EFI - Mustang Evolution
Old 01-01-2011, 07:26 PM   #1
Qwik Four Six's Avatar
I've got a 89 4 cyl conversion with a carbourated 302. Will a 4 cyl computer and wiring be sufficient if I still have 4 cyl gauge cluster. Or do I need 5.0 computer and wiring?
Qwik Four Six is offline   Reply With Quote
Old 01-01-2011, 09:59 PM   #2
Re: Foxbody switching to EFI
Depends on the ignition setup your 4 banger had, if it was 8 spark plug 4 banger then no, all others will work. I myself would convert to the duraspark or go with a msd ignition.
Straublittleman is offline   Reply With Quote
Old 01-01-2011, 10:00 PM   #3
ibleedblue65's Avatar
I have not done one but own a converted car and have replaced harnesses. The engine and pcm harness are separate from the body harness I think. All you should need is a5.0 computer and engine harness. It's pretty easy. The dash harness is not changed.
ibleedblue65 is offline   Reply With Quote
Old 01-01-2011, 10:05 PM   #4
Also I know on the older fox's they had a switch on the gauge cluster near the right hand side at the top that you can switch it so your rpm gauge would be accurate, Don't know if its like that on the newer ones, the one I had was a 79.
foxbody
Switching to Cobra IRS! MustangScott Pre-2005 V6 Mustang 55 08-22-2010 07:27 PM
and i said i'd never own a foxbody... 04TRV6 1979-1995 Mustang GT 38 03-23-2010 10:27 AM
switching top and frames at the same time flysure1 1979-1995 Mustang GT 1 01-14-2008 12:04 PM
switching to 5 speed stovalini69 1996-2004 Mustang GT 7 11-30-2006 12:19 AM
Switching to 4.10.....questions Ghostbuster Pre-2005 V6 Mustang 6 08-19-2004 01:00 AM
05:36 PM
