Water pump bolts... - Mustang Evolution
Old 01-03-2011, 08:43 PM   #1
BrKu789's Avatar
Send a message via AIM to BrKu789
Water pump bolts...
Alright guys I've been having many problems with removing this water pump (Mostly because i do not know what i'm doing!) but i got all but two bolts off. The bolt i am hating trouble with is the one on the bottom of the water pump near the crank shaft. I can't fit a anything over the bolt because the crank shaft is right in the way. Is there a trick to this? How do i remove this bolt? AN help would be good right now!
Thanks,
Brandon
NEXT TO SEX, MY MUSTANG IS BEST
BrKu789 is offline   Reply With Quote
Old 01-03-2011, 10:13 PM   #2
If I'm not mistaken, you will have to remove the crank pulley. That's probably what's in your way.
93CobraGuy is offline   Reply With Quote
Old 01-03-2011, 10:36 PM   #3
sixty6fastback's Avatar
I concur, the dampener needs to be removed.
1966 Mustang Fastback HiPo 289 full roller, 4-Speed Toploader,9" w/ 3.70's
sixty6fastback is offline   Reply With Quote
Water Pump Bolts audi_b Pre-2005 V6 Mustang 3 08-30-2009 02:34 AM
Changing Water Pump wvstang5.0ho 1979-1995 Mustang GT 9 07-13-2008 10:45 PM
water pump ? jumpman1203 Pre-2005 V6 Mustang 0 10-16-2006 01:25 AM
Water Pump Going Bad? mydi777 Pre-2005 V6 Mustang 5 03-22-2005 09:52 PM
water pump replacement Ponycarman Pre-2005 V6 Mustang 3 01-16-2004 11:26 PM
08:57 PM
