351w 1979 mustang wont start - Mustang Evolution
Old 01-04-2011, 09:44 AM   #1
I've been building 79 with a 74 351w. I have done most of the work myself but the first owner put In a electric fuel pump, the engine is in and ready to start it turns over but fire up. I did time it to a 302 because of the 302 cam and I'm not sure about the fuel pump it sounds like it running all the time. I have the mech fuel for the 302 will that work in a 351w. Any help is good thank you.
Dexter is offline   Reply With Quote
Old 01-04-2011, 01:49 PM   #2
Blustreek's Avatar
Region: Hawaii
Re: 351w 1979 mustang wont start
Dude,Is this motor injected or carbed? If injected,Check fuel pressure
at FR schrader valve w/a tester. There should be I think 60/70psi.
straight sys. pressure from pump to rail with regulator vac.port plugged and eng.off not running,Any less than it's the pump that's faulty.But if there's fuel up in vac. hose,replace regulator. Mech. pump you got should work on your 351w.
Blustreek is offline   Reply With Quote
Old 01-04-2011, 02:03 PM   #3
stampde's Avatar
first of all wich 302 cam ??? if its an h.o. cam it has the 351w firing order / did you check the timing ? TDC ? If its squirting fuel through the carb and you have spark at the plugs then its a timing issue ,or firing order
2011 GT Auto
Old 01-04-2011, 08:48 PM   #4
It is a carb engine and the timing is for a non HO and so is the cam, when I hook up the batterie the fuel pump is humming all the time so it must be wired in wrong but I am going to put in the mech pump, then at least I know I'm getting fuel. Whats the best way to check for spark? Thanks you guys.
Old 01-04-2011, 08:58 PM   #5
I usually just take an old plug and plug it into the coil wire and have someone crank the engine if it sparks, well, you got your fire. Low light works best, and doing this you can also check each cylinder as well. Just don't touch it while its cranking. Not fun, trust me lol.
93CobraGuy is offline   Reply With Quote
1979 mustang
2004 Mustang GT turns over but wont start. Lola 1996-2004 Mustang GT 9 08-31-2010 10:35 PM
95 mustang wont start, ignition problem? Billy95Gt 1979-1995 Mustang GT 5 07-29-2010 10:03 PM
wont start???? bluestang1724 1979-1995 Mustang GT 11 01-04-2008 10:10 AM
wont start joezappitella 1979-1995 Mustang GT 5 12-04-2007 09:17 PM
04 Mustang v6 3.9L wont start mammadawn Pre-2005 V6 Mustang 16 04-03-2007 10:49 AM
11:47 PM
