1500 - Mustang Evolution
Old 01-04-2011, 08:42 PM   #1
1500
Ok so I have a 94 Gt ragtop current mods are exhaust cold air intake under drives new stage 3 clutch and I have about 1500 bucks to put in to modding the car so how do u guys think I should spend it?
Burn rubber not your soul
94black5.0 is offline   Reply With Quote
Old 01-04-2011, 10:37 PM   #2
Gears, heads, and a good set of tires
Cobracoupe5 is offline   Reply With Quote
Old 01-05-2011, 03:21 AM   #3
Gears,tuner,heads,rubber. Any if those
Old 01-05-2011, 07:04 AM   #4
Re: 1500
yea gears are a great bang for the buck. A good set of heads/intakes/cam would be nice but you wont find it for 1500.
Old 01-05-2011, 11:18 AM   #5
Well I have a brand new set of good year gatorbacks on it...... So with a tuner gears and a used set of gt40 heads what kind difference can I expect
Old 01-05-2011, 12:38 PM   #6
I'm not sure hp wise but one of my old cars had 3.73 gears, stock heads, cold air kit, 73 mm air meter, 65mm tb, exhaust, stock cam and intake, with some cheap 245 45 17 tires and it would run consistent 13.80's speed shifting at 5500 and launching at 1200rpm so it would hook up.
Old 01-05-2011, 01:17 PM   #7
Re: 1500
dont just do heads, if you go through all that trouble do a cam and intake set as well
Old 01-05-2011, 10:25 PM   #8
What's the best h/c/I bang for ur buck combo uthink
Old 01-06-2011, 07:58 AM   #9
Re: 1500
im no expert on fox bodies and I am sure someone can chime in here, you can probably find some GT40 alum heads and maybe a nice knock off brand edlebrock intake set with a custom cam
Old 01-06-2011, 06:28 PM   #10
ibleedblue65's Avatar
The right thing to do is either hci or gear. In your price range I don't think you will get to far on hci but you might be able to get a set if afr's a good comp cam and grab a gt40 intake off an explorer in a junkyard. Then you can always upgrade later.or you could get some gt40 heads and intake off an explorer, grab a trick flow cam and still do the gear and stay in budget. Depends on how much you plan to do yourself. Don't tune yet, it isn't necessary. I would probably do the afr heads a comp can and the gt40 intake and save up for the gear. You can grab the injectors off the exploder as well, just don't install them until you are ready to tune. Once all of this is done you will eventually need a decent sized throttle body and maf.
ibleedblue65 is offline   Reply With Quote
Old 01-06-2011, 06:37 PM   #11
WhiteCobra94's Avatar
Get the new Edelbrock E-street aluminum heads with cam, for around $900 it's the best out there brand new for what you wanna spend !! Google them (SBF edelbrock e-street heads ) and if so make sure you get the ones with 1.90 runners because you have stock pistons !
Old 01-06-2011, 09:48 PM   #12
Just realized this is a convertible. SUB FRAME CONNECTORS!
Old 01-07-2011, 07:53 PM   #13
So for 1500 bucks do u think I could get in high 13's
Old 01-07-2011, 08:36 PM   #14
Get some gears and some MT streets and you'll be in the low 13's
Old 01-07-2011, 08:42 PM   #15
With what I'm running now what u think I'll run
Old 01-08-2011, 07:41 AM   #16
High 14's if you have shifting skills. Am I close?
Old 01-08-2011, 12:18 PM   #17
Yea mid 14's when it hooks.... And with a decent head cam intake MaF and throttle body gears and a tune what u think I'll run
Old 01-08-2011, 12:20 PM   #18
Twelve s on slicks if you can drive.
Old 01-08-2011, 12:22 PM   #19
if you don't break that t5. And That's with a good hci.
Old 01-08-2011, 12:26 PM   #20
The t-5 Should hold up to that right
Old 01-08-2011, 12:30 PM   #21
Um I doubt it. I have broken them on nearly stock motors with some traction. If you plant to build a 5.0 an aftermarket transmission is a reality unless you go auto. You can get 3550's kind of cheap now.
Old 01-08-2011, 12:40 PM   #22
What manual trans would u recommend
Old 01-08-2011, 12:53 PM   #23
You can get used 3550's In the $ 1000 range. I believe they are ratedto 400 or 450. Or tko but you are goin to spend a lot more.
Old 01-08-2011, 12:55 PM   #24
I would hold off on the trans a wile though cause you can get away with the t5a little longer if you drive it right. Definitely lift for third.
Old 01-08-2011, 01:03 PM   #25
I never really speed shift or anything
Old 01-11-2011, 07:36 PM   #26
Titus Wadicus
svtlx's Avatar
Re: 1500
i think you should find someone hard up for cash with a blower (still installed on car so u know it works). bar none...it's the most bang for your buck..right up there with a gear set. if i had it to do over again.. i would bought boost first, then all the other crap second. but on the otherhand, it's not always a good idea to go boost till u learn a bit bout the rest of the car.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Wanted: WTT or WTB 99+ Chevy/GM 1500 A5295 Mustangs for Sale and Wanted 0 09-28-2009 12:48 AM
DAMN!! if only I had an extra 1500!!!! sonic04edge The Bar 7 11-15-2005 05:28 PM
woot @ 1500 dark The Bar 3 12-07-2004 07:15 AM
1500 Members Brent The Bar 20 09-06-2004 09:18 PM
11:34 PM
