have i struck gold???help - Mustang Evolution
Old 01-06-2011, 09:02 PM   #1
whats up everybody any fox gurus out there found 2000 mercury/explorer 4x4 5.0 i didnt know they still put 5.0 after 95 so i check it out looks like same intake gt 40 mass air # xf2f-12b579-aa 9m03-2 need cross refrence # anybody know if and what i found havent looked at eec yet thanks
Afterhours is offline   Reply With Quote
Old 01-06-2011, 09:55 PM   #2
ibleedblue65's Avatar
Do some research. I don't know off the top of my head but some of them have gt40 heads and some had gt40p heads. If I remember correctly the p heads won't work because it requires different headers. They do have a cast gt40 upper and lower. Also 24lb injectors. Just don't pay too much $ 200/250 for the heads $ 100 tops for the intake although that is high. I wouldn't pay a whole lot more than $ 70. The throttle body and mass air may be larger as well but I don't remember.
ibleedblue65 is offline   Reply With Quote
Old 01-06-2011, 10:47 PM   #3
Thanks man I was going give 600 for it had rod knock.
2000 merc mountainer 5.0 found few good web site 4 cross ref # 4 88-93 and found web sites where u can buy that mass air sensor with that # but can I use intake EEC injectors r they 24 lbs. And times r tough so make me feel good bout Gettin all my upgrades bargain I got 88 lx 5.0 hatchback still on speed density. I'm at it's limit thanks 65
ID:	22623   Click image for larger version
Old 01-07-2011, 08:57 AM   #4
Alright, you could use the computer and harness to convert to mass air but keep in mind those things had coil packs instead of tfi. I'm sure you could still convert everything over and it would be kinda cool. Pretty sure there is a tone ring in the dampener for crank position and I know there is a cam position sensor that drops where the distributor would be. If you went this route you could use the injectors and maf without a tune. Can't remember if the pcm is in the kick panel oz the exploder or not, might be some harness length issues. Yes it has 24lb injectors. I believe those exploders were rated around 260/270so not a bad upgrade. I hope I answered all of your questions.
Old 01-07-2011, 03:57 PM   #5
stampde's Avatar
Re: have i struck gold???help
you dont need diff headers for p heads , reg 5.0 headers do work just get in the way of 2 spark plugs ,but only a little / been there done that and the p heads make good power
2011 GT Auto
Old 01-07-2011, 05:50 PM   #6
There's you're answer. I haven't done it, I had just heard about the plug issue. Will a shorter plug fix it? Our does a factory plug still work just a pita?
Old 01-10-2011, 09:36 PM   #7
Titus Wadicus
svtlx's Avatar
i got one in my garge floor out of a 98. gt40 heads are factory 93 cobra heads. gt40(p) are the revision heads..smaller valves, but more flow because the velocity is picked up. any 119.00 set of ebay headers will work (havent tried oem). the intake is also a revised cobra intake..(better flow than actual cobra). also, if explorers have 24lbs inj it's news to me. mine came wit 19's..my neighbor has a mountaineer 5.0 and it's 19's also. however, that motor with a 70ml throttle body, e-cam, and 24lb inj. is supposed to be good for 300hp@ the crank (or kinda close anyway). dont run anything larger than an e-cam (.498 lift) or .500 lift cam. the combustion chambers are smaller than e7's...and the pistons will become intimate with the valves. stay with 1.6rr or stock rockers.
also, it is way easier to convert to mass air with your existing harness and a mass air ecm than it is to convert your whole car over to wut i believe is an obd2 system.
your gt harness already has the holes blanked/empty for you to add mass air. you can use the plug and meter from the explorer if you have too.
the meter has 4wires...signal in...signal out...hot..& ground. and add a mass air pcm. believe me when i tell u that it is way easier to hook up 4 wires than to rewire the whole car.
everything your doin..i've done it.
let me know if i can be of any more assistance, and i hope my info helped.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-10-2011, 09:38 PM   #8
Titus Wadicus
svtlx's Avatar
also, u can get 24lbs out 2k up taurus in a junkyard if (new) ford racing is out of your budget. they are the same color (blue) and i think the same part number.
Old 01-10-2011, 10:43 PM   #9
Cool , thanks for info It makes me feel good bout payin fraction of cost for upgrades If u do some checking u find good deals I picked me up mass air meter/sensor & PCM A9p $100 bucks.Upper/lower intake 2000 explorer gt40 100. I was told with these & set off gt40p heads 50+ more hp not bad for couple hundred bucks. I found some pre mass air 5.0 junkyard cheap & here pic of injectors (I think Alot of 90's ford f150 5.8 had 24lb injectors I'm only goin on pics but matched up perfect )also 93-01 Lincoln mark 8 24lb. Chrome won't get u home thanks
ID:	22705   Click image for larger version
Old 01-10-2011, 10:52 PM   #10
Titus Wadicus
svtlx's Avatar
im not sure where u r getn your info from..but 5.8 f150's r 19's... and mark 7is just a mustang motor in a lincoln ..19's. i cant quote u for sure on the mark8 4v..but i bet their 19's as well. i can just tell you for a fact that 2k up taurus use 24lbs inj (blue skinny pencil type). there's lots of them in the junk yard. trust me, all the trucks are 19's. that's not a bad deal on the parts. i think i paid 500 for my whole motor wit under 100k
Old 01-10-2011, 11:22 PM   #11
Veryuseful.com but like any 3rd party info it don't hurt ? It . I'm always on hunt for new ways get the most out nothing. Junkyards r my toy store
ID:	22707   Click image for larger version
Old 01-11-2011, 11:56 AM   #12
Titus Wadicus
svtlx's Avatar
well ill be the first to admit i dont know everything. p.m. or something if i can help you with anything. i was just tryn to give u info i know for a fact. there's alota ppl out there give'n info and have nevr even tried the shyte out themselves...
Old 01-11-2011, 12:36 PM   #13
stampde's Avatar
shorter plugs DO FIX IT , But you can still use reg plugs , there just a little tuff to get in and out , i had to use an open end wrench to get them , not to bad ...
2011 GT Auto
Struck again Scut95 The Bar 8 08-21-2008 07:17 AM
nxt vs gold class carlosc Mustang Audio & Video 7 03-01-2007 10:23 PM
The Mustang Evo Curse has STRUCK Again ComputerGuy The Bar 25 08-18-2005 09:17 PM
Rims for Gold stang......... Morpheus The Bar 5 08-09-2003 03:05 PM
Rims for my gold stang......... Morpheus Mustang Audio & Video 6 08-08-2003 05:20 PM
03:52 AM
