scored some 3.73's - Mustang Evolution
Old 01-06-2011, 09:53 PM   #1
GUDNEVL's Avatar
scored some 3.73's
for 51$bucks shipped to me!now just to try and figure out how to put them in,lol
1989 mustang gt,short headers,3.08 gears,off road h pipe,flows,cold air intake,smog pump delete,fresh tune up,push button start,gt fog light fix ,everything else pretty much stock
most recent mod:blown head gasket
GUDNEVL is offline   Reply With Quote
Old 01-06-2011, 10:19 PM   #2
Send a message via AIM to Nitto Stang
Cool man install's not bad at all for 50 that's a steal good luck with the install
Nitto Stang is offline   Reply With Quote
Old 01-06-2011, 11:27 PM   #3
Installing gears is a pretty involved process. There are a lot of tolerances that need to be just right for them to mesh properly. Professional installation is definitely reccomended, unless you have done it before. Shouldn't cost more than about $300 to $350 to have a pro do it for ya!
93CobraGuy is offline   Reply With Quote
Old 01-07-2011, 07:38 AM   #4
Re: scored some 3.73's
if they are used accept that they may make noise once in the car, even if used only for a bit. If you are ok with that then get someone to put them in (its not just something anyone should attempt as its not hard but there are special things that have to be done/measured to get it right)
and as said above if you plan to pay 300 bucks to install them the only install new parts and rebuilt your tlok unit while you are doing it as it has to come out anyway.
Old 01-07-2011, 09:01 AM   #5
If you are going to do it, do it right and be done. Have the traklok rebuilt, get an install kit and fluid and take it somewhere. There are lash settings that need to be measured, etc. You could do it yourself if you love that rear end whine, but you will be happier having someone do it for you. Check out nationaldrivetrain.com for install kits etc.
Vendetta is offline   Reply With Quote
Old 01-07-2011, 09:26 AM   #6
Nice score!
Old 01-07-2011, 12:07 PM   #7
All excellent advice!! +1
Old 01-07-2011, 12:44 PM   #8
stampde's Avatar
I've put in at least 15 sets .. it's not easy / in and out a few times or more till you get the shimming right ....
But believe it or not , I've installed Ford racing ring and pin's (new) with out setting them up ,just re-using the old shims and they NEVER whine .. i think the factory gears are made so well they just match ??? that's my theory ....
but if you've never done them ,have someone else do it right ... good luck
2011 GT Auto
Old 01-16-2011, 07:46 PM   #9
94 Mustang GT's Avatar
Glad to know im not the only one that thinks they wont whine! lol
94 Mustang GT is offline   Reply With Quote
Old 01-17-2011, 10:57 AM   #10
ibleedblue65's Avatar
Not saying you can't get lucky, but I would never advise installing a gear without setting correct pinion depth and back lash.
ibleedblue65 is offline   Reply With Quote
3.73's installed ( need speedometer help ) big show 98 Pre-2005 V6 Mustang 8 12-25-2009 06:33 PM
3.73's and T-Lock among other Q's dusty97 Pre-2005 V6 Mustang 7 09-10-2008 02:53 PM
3.73's Sassa Massa 1979-1995 Mustang GT 3 04-13-2007 03:02 PM
how much will 3.73's do? bigpomps Pre-2005 V6 Mustang 13 01-07-2006 12:14 PM
Woohoo scored a second job!! sonic04edge The Bar 18 12-30-2004 02:31 PM
08:42 AM
