Spark Plugs? - Mustang Evolution
Old 01-11-2011, 06:46 PM   #1
WhiteCobra94's Avatar
Spark Plugs?
What's up guys, I was wondering if anyone could tell me the correct spark plug to use, ( I have a stock 302 lower end, with Edelbrock Heads, Intake, Cam with .498 lift, 24lb injectors with 75mm mass air, 190lph fuel pump, pulleys, bassani headers, bassani off-road x pipes with 2 chambered flowmasters pretty much every bolt on except a blower! Just look to see what spark plugs would work best ) Thanks guys!!!
Old 01-11-2011, 08:28 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Spark Plugs?
i use accel u-groove. motorcraft are good too if u can find them
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-11-2011, 09:58 PM   #3
On a stock headed car I have always used motorcraft or autolite plugs but when I switched to the afr's I went with what afr recommended for their head I would call edelbrock since they may have a preferred plug and gap for your combo.
Cobracoupe5 is offline   Reply With Quote
Old 01-12-2011, 03:53 PM   #4
Yea I was just reading it today they recommend Champion RC12YC spark plugs for my set up!
Old 01-12-2011, 07:57 PM   #5
Cool. Glad you found out which ones you needed.
Old 01-13-2011, 12:54 PM   #6
94 Mustang GT's Avatar
Re: Spark Plugs?
Use what plug you want to, but go with a colder plug then what came from factory!! Idk what heat range to use, ill find my info i had cause thats what im going to do is use a colder heat range i just dont remember what exactly i did with my info! lol
94 Mustang GT is offline   Reply With Quote
Old 01-13-2011, 01:36 PM   #7
I like autolite 24's and motorcraft. Those r the only plugs that go in my motors
90LX5.0 is offline   Reply With Quote
spark plugs Perry Wyatt 2005-2010 Mustang GT 11 04-19-2010 08:31 PM
Spark plugs upton7 General Mustang Discussion 15 02-02-2010 03:00 PM
spark plugs v6stang04 Pre-2005 V6 Mustang 4 01-24-2010 07:22 PM
what spark plugs do i need fastfanatic 1996-2004 Mustang GT 6 09-14-2009 09:23 PM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 07:36 AM
08:00 AM
