operating system - Mustang Evolution
Old 01-11-2011, 07:35 PM   #1
workmail21's Avatar
operating system
This is probably a stupid question but is the 94 gt odb2 or odb1
workmail21 is offline   Reply With Quote
Old 01-11-2011, 07:42 PM   #2
Titus Wadicus
svtlx's Avatar
Re: operating system
obd 1....the official start is in 97. but ford went ahead and put obd2 in the tbirds a couple years early
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-12-2011, 04:48 AM   #3
workmail21's Avatar
Ok thanks a lot
Old 01-12-2011, 07:16 AM   #4
they are harder to tune but there are some great tuners out there that can do it
Old 01-12-2011, 09:48 AM   #5
Titus Wadicus
svtlx's Avatar
i think obd1 systems are good for the novice. playn wit injectors and fuel pressure taught me alot. call me old school, but i prefer obd1. everyone has a preference.
Old 01-13-2011, 11:59 AM   #6
94 Mustang GT's Avatar
Actually OBD II started in '96. Ford did have a few OBDII before then though
94 Mustang GT is offline   Reply With Quote
Old 01-13-2011, 12:01 PM   #7
ibleedblue65's Avatar
Ya there are some t birds out there that are 95 with obd2.
ibleedblue65 is offline   Reply With Quote
Old 01-13-2011, 12:07 PM   #8
That idk but i do know it was federally mandated by the gov to have ODBII in 96 and newer!
Old 01-13-2011, 12:35 PM   #9
I just learned something because I thought it was. 94! Thanks for asking
90LX5.0 is offline   Reply With Quote
Old 01-13-2011, 12:41 PM   #10
Titus Wadicus
svtlx's Avatar
im still pretty sure it was 97...but maybe it was 96.. we r debating 12months, so we r all pretty knowledgable in this thread
Old 01-14-2011, 01:48 AM   #11
The 94-95 gt had obd 1 but the v6 had obd2 in 94-newer on the mustangs and yes it was mandate in 96 to have obd 2.
Straublittleman is offline   Reply With Quote
Old 01-14-2011, 04:36 PM   #12
WhiteCobra94's Avatar
I have a 94 what's a good tuner and or chip to use?
Old 01-14-2011, 07:17 PM   #13
If you have a 94 cobra or v8 then you need a chip, sct has about the best chip you can buy, you're able to switch between like 4 different tunes. If you have a 94 v6 then you can buy a hand held tuner from sct and flash the tune onto your ecm. I myself like sct but diablo sport also has a good hand held and I don't know if they make chips or not.
Old 01-14-2011, 08:05 PM   #14
I have a 94 cobra , with the Edelbrock upper power package , stock 302 lower end
need opinions on new sound system for 98 cobra with Mach system tennisfreak802 Mustang Audio & Video 7 04-28-2010 01:29 PM
My New System Rellik Mustang Audio & Video 12 03-16-2005 08:51 PM
What my new system will be. Dom Mustang Audio & Video 9 12-21-2003 12:32 AM
OK, Here's my system as I'm seeing it now. Dom Mustang Audio & Video 4 11-17-2003 12:09 PM
New System Brent Mustang Audio & Video 7 05-12-2003 01:44 PM
06:16 PM
