Hi im having tranny problems - Mustang Evolution
Old 01-18-2011, 08:19 PM   #1
It grinds from first to second only on those two
302fritz is offline   Reply With Quote
Old 01-18-2011, 08:20 PM   #2
What should i do plz help
Old 01-18-2011, 08:24 PM   #3
ibleedblue65's Avatar
Synchro. Rebuild transmission.
ibleedblue65 is offline   Reply With Quote
Old 01-18-2011, 08:25 PM   #4
Or try some gm synchro mesh and see if it helps.
Old 01-18-2011, 08:31 PM   #5
Thanks im sorry i really dont know that much around how much would it cost me to renuilt the tranny and whats a mesh
Old 01-18-2011, 08:35 PM   #6
Depends on the shop. Call around and get quotes. It probably just needs one synchro but it could be the gear itself or the fork. Gm synchro mesh is a fluid made by general motors for transmissions. It is great at clearing up shifting problems.
Old 01-18-2011, 08:39 PM   #7
Oh men thanks alot im going to try that thanks again
Old 01-19-2011, 09:02 AM   #8
What tranny do u have.
Alscobra is offline   Reply With Quote
Old 01-19-2011, 09:19 AM   #9
I would guess t5.
Old 01-19-2011, 09:24 AM   #10
Re: Hi im having tranny problems
try taking up slack in the clutch cable, probably wont help any but its a free thing to do.
car is off, push in the clutch with your left hand all the way and take your right hand and put over the quadrant (above the gas petal, its white/plastic and you can see the clutch cable going over the top of it.
Ease out of the clutch petal slowly while holding tension against the quadrent wanting to rotate, it must rotate but you are just holding it back while it turns with pressure. You will hear a click as the clutch comes out. Do a couple clicks.
The adjustment should raise the clutch petal up a bit and firm it up, drive the car at 55mph or 45 what ever holding the gas steady ease in the clutch the rpms should not rise until you have more than a half inch of the clutch petal pushed in, then you are ok. Any less and its to tight.
To remove adjustment just lift up on the underside of the clutch petal with your foot, hard shifts may unadjust this and require you to redo it.
Old 01-19-2011, 03:49 PM   #11
iwannagofast's Avatar
haha tranny problems, arent all trannys a problem? ya dont know if its a man or woman. Imagine see a smokin hunny at a bar and ya take her home and when ya start to get it on ya find out that she is really a he! Now thats a tranny problem!
iwannagofast is offline   Reply With Quote
Old 01-19-2011, 03:59 PM   #12
DAS RITE!!! LOL
Old 01-19-2011, 06:47 PM   #13
I'm guessing you speak from experience here. Lol
Old 01-19-2011, 07:21 PM   #14
i have a t5
Old 01-19-2011, 10:11 PM   #15
Thank god its not from experience but if it ever happens ill let ya know, maybe ill even take a pic for ya
Tranny problems with my 97 Cobra Sparkdic 1996-2004 Mustang GT 0 04-28-2010 07:38 AM
1997 Cobra tranny problems oojdbozoo 1996-2004 Mustang GT 5 05-13-2009 01:57 AM
Diagnosis help! Tranny/PATS alarm problems Pewter04 1996-2004 Mustang GT 1 03-15-2009 03:08 AM
tranny or throttle problems? SexyLilSeaOtter 1996-2004 Mustang GT 2 03-08-2009 11:08 PM
What Tranny? Smokedya95stang Pre-2005 V6 Mustang 7 03-20-2004 06:06 PM
04:19 PM
