Cam lift's? - Mustang Evolution
Old 01-19-2011, 06:06 PM   #1
WhiteCobra94's Avatar
Cam lift's?
What's the highest lift cam I can use with stock shortblock and pistons?
Old 01-19-2011, 06:14 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Cam lift's?
wut year stang you have?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-19-2011, 06:21 PM   #3
94 cobra, i was gonna do the idle to 5500 setup but I think I might do the 1,500 to 6,500 setup I'm just trying to find the best head/cam package
Old 01-19-2011, 06:26 PM   #4
Titus Wadicus
svtlx's Avatar
Re: Cam lift's?
if u change heads..then the max lift cam you can run will most likely change. the size of the cumbustion chambers plays a huge part in cam selection. when you buy your heads you need to talk to the company to find out your options on a stock bottom end with their head
Old 01-19-2011, 06:46 PM   #5
bbunt302's Avatar
Re: Cam lift's?
Probably much higher than you need unless you go with heads that have some SERIOUS flow. There's too many factors that come into play to give a specific number though. Plus, you should always measure to be sure, regardless of whether not the same combo worked for someone else. Every engine is different.
Scary stuff.
Old 01-19-2011, 06:50 PM   #6
Titus Wadicus
svtlx's Avatar
Re: Cam lift's?
yup, u better clay those pistons...lol.
Old 01-19-2011, 07:48 PM   #7
[QUOTE="svtlx"]if u change heads..then the max lift cam you can run will most likely change. the size of the cumbustion chambers plays a huge part in cam selection. when you buy your heads you need to talk to the company to find out your options on a stock bottom end with their head[/QUOTE
Well there's 3 setups I'm thinking of Using, in the idle to 5,500rpm range is the Edelbrock performer 5.0 Heads w/ the performer cam with, .498 lift, or the 1,500 to 6,500rpm range with the Edelbrock RPM heads and cam,...... And the 3rd is Ford Racing GT40 Turbo Swirl heads , but I don't kno what cam to match with them!
Old 01-19-2011, 08:21 PM   #8
Titus Wadicus
svtlx's Avatar
Re: Cam lift's?
depends on your rear gear and how u plan on driving it as far as cam selection. are you gonna be up at 6500 all the time
Old 01-19-2011, 08:23 PM   #9
sixty6fastback's Avatar
Sounds like a call to Comp Cams is what you should do. Go to the horses mouth...
1966 Mustang Fastback HiPo 289 full roller, 4-Speed Toploader,9" w/ 3.70's
sixty6fastback is offline   Reply With Quote
Old 01-19-2011, 08:25 PM   #10
No not really It's only gonna be a weekend driver, my trans is built up for 500hp I have aluminum drive shaft and 4:10s in the rear now ,.... I'm bot looking for crazy HP just something fun when I have the car out, im painting it in the spring and I'm redoing the interior now
Old 01-19-2011, 08:31 PM   #11
Titus Wadicus
svtlx's Avatar
Re: Cam lift's?
if you got an auto...i think the 5500 would be ok.
Old 01-19-2011, 09:00 PM   #12
Yea it's a AODE
Old 01-20-2011, 09:36 AM   #13
Yea it's a AODE
Yea I'm prob gonna stick with the Edelbrock Performer 5.0 package
Old 01-20-2011, 09:36 AM   #14
Your ptv clearance isnt solely based on lift. Its also based on your lobe seperation. Thats also where a lot of your sound comes from. I have heard on stock heads that .544 lift is about the max. My car has an e cam in it now but i am changing my setup and the e cam clears no problem with .498 lift. I would check any cams ptv neway but a lot of guys run a .512/.512 cam with no problem and some guys run an e cam and 1.7s with no problem and thats approx. .524/.524.
Vendetta is offline   Reply With Quote
Old 01-20-2011, 12:13 PM   #15
Well I have 1.6s and it's either gonna be the E-303 or the Performer 5.0 cam, they there both .498 I think and the dur, is almost the same about a .002 difference
Old 01-20-2011, 12:54 PM   #16
The 5.0s respond better to more duration on the exhaust side. I would recommend staying away from the letter cams. My e cam pulled harder than the stock cam but it just doesnt hold a candle to some of the other ots cams out there. If youre looking at a hci package the trickflow setup is decent. The tf stg 1 is a decent cam that a lot of people have had success with.
Old 01-21-2011, 01:18 PM   #17
Well I already have the Edelbrock Performer 5.0 intake , would that work with the trickflow twisted heads?
Old 01-21-2011, 03:41 PM   #18
Yes. Or you could hock the performer and get the whole trickflow setup. Or get eddy heads and use a tf stg 1 cam. All up to you.
Old 01-21-2011, 03:59 PM   #19
1ijack's Avatar
Send a message via Yahoo to 1ijack
Re: Cam lift's?
The trick flows twisted wedge heads and Track heat intake and their fuel rail and their cams is what I am going to soon as I get the extra money. They have a real nice setup.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 01-22-2011, 10:21 AM   #20
Now that mix matching heads and cam will that hurt anything or as long as it's the same power range !
Old 01-22-2011, 02:23 PM   #21
You may not get the very best performance possible but if you do your research you should come up with a good combo for your car.
Cam sikkstang 1979-1995 Mustang GT 28 04-25-2009 10:49 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
cam and rr? cjd10 Pre-2005 V6 Mustang 16 02-08-2005 04:12 PM
06:33 AM
