When i step on the gas, I go out of control! - Mustang Evolution
Old 01-19-2011, 06:32 PM   #1
BrKu789's Avatar
Send a message via AIM to BrKu789
Alright, I have a 1994 Mustang GT.
As i'm going down the road i want to speed up so i step on the gas a little harder and i'm pretty sure it goes from 4th gear to 3ed, but anyways my tires began to start spinning uncontrollably, and this is scary when i'm going 50 down a pretty urbanized road.
This has actually happened to me a few times and i'm, just wondering if this is normal or if my tranny is shifting down to quickly or anything?
Any feedback will be appreciated....
P.S.
I may need new tires so which i am suspecting has to do with it as well... But their not so bad that they have to spin uncontrollably on a moderately dry road...
Thanks,
Brandon
NEXT TO SEX, MY MUSTANG IS BEST
BrKu789 is offline   Reply With Quote
Old 01-19-2011, 06:36 PM   #2
Titus Wadicus
svtlx's Avatar
Re: When i step on the gas, I go out of control!
is your engine stock? is the rear end stock?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-19-2011, 06:51 PM   #3
BrKu789's Avatar
Yeaa the engine is stock with 153,XXX Miles on it. We recently did get the rear axle replaced if that makes any difference... But the tranny is also rebuilt, and i don't know how many miles are on that because the previous owner did not tell me.
Old 01-19-2011, 06:58 PM   #4
Titus Wadicus
svtlx's Avatar
i would say that the line pressure in your tranny is too high, but have have an aod(e) which is electric. the computer handles the shift points and line pressures. perhaps the previous owner loaded a tune in the car for the trans.
Old 01-19-2011, 07:18 PM   #5
BrKu789's Avatar
Alright thanks for your input! Would i have to go to some mechanic and ask them to switch it for me or something? Is it something i could do myself? I know the previous owner messed with the computer a little because there is an air bag cancel code on there as well, which is fine but i dont like the hard shifting...
Old 01-19-2011, 07:38 PM   #6
Titus Wadicus
svtlx's Avatar
i think u will have to pm spectorv or bbunt. im not famliar pcm tuning
Old 01-19-2011, 08:24 PM   #7
Check and make sure they plugged in the line pressure sensor on the tranny, it's right above the neutral safety switch and shift linkage. If this is unplugged it will shift reeeeallly hard. Mine was unplugged with a 3.8Lv6 and would spin the tires every time it shifted from 1st to 2nd and to drive but would only shift real firm into overdrive.
Straublittleman is offline   Reply With Quote
Old 01-19-2011, 08:27 PM   #8
Titus Wadicus
svtlx's Avatar
ur a smart dude....
Old 01-19-2011, 08:54 PM   #9
Svtlx: your a funny guy. Lol
Alscobra is offline   Reply With Quote
Old 01-19-2011, 09:07 PM   #10
Titus Wadicus
svtlx's Avatar
my gf just says im funny look'n
Old 01-19-2011, 09:16 PM   #11
Rule #1:
let no bad advise go unpunnished.
Old 01-19-2011, 09:19 PM   #12
ur a smart dude....
Thanks but mainly a smart :asshat:
Old 01-24-2011, 09:46 PM   #13
94 Mustang GT's Avatar
94 GT's require a chip not a tune, so it cant be tuned! It might have a chip but i dont think that would have anything to do with the tranns shifting. My 94 GT with brand new (less than 2k on tires) is all stock so far also breaks the tires loose!
94 Mustang GT is offline   Reply With Quote
Old 01-24-2011, 09:51 PM   #14
Titus Wadicus
svtlx's Avatar
i had a 96 tbird that chirped the tires regularly. im not a big fan of the electric units
Old 01-25-2011, 10:28 AM   #15
Of course a chip has to do with an auto shifting. Tunes shift points, etc. And they require a chip to hold a tune. You cant just reflash the ecm like an obd-ii. Are you sure you graduated from uti 94 mustang?
Vendetta is offline   Reply With Quote
Old 01-25-2011, 10:44 AM   #16
Gster's Avatar
What type of tires do you have, if they are cheap hard *** rubber tires it will spin all the time.
Gster is offline   Reply With Quote
Old 01-25-2011, 10:01 PM   #17
See if you werent such a ****** youd know that when people refer to a "tune" they mean re flash the pcm! Thats why people ask about a tune or a chip! Whats uti? hey i got a question what is a good brand of blinker fluid?? A buddy says royal purple works good, is that true???
Old 01-25-2011, 11:38 PM   #18
Titus Wadicus
svtlx's Avatar
i wasnt goin to say nuth'n bout the obd1 reflash...but im glad u put it out there. i thought slick 50 was a good blinker fluid
Old 01-26-2011, 07:05 PM   #19
Bahahahaha ....feel the love
Old 01-26-2011, 09:08 PM   #20
I wen to k mart today and they didnt have any of the slick 50. i thought if anyone had it k mart would! where you get it at?? i wanna try it!
Old 01-26-2011, 09:22 PM   #21
I think you can find it right beside the how vehicles run on ethanol department
Old 01-27-2011, 04:29 AM   #22
Whicked93Cobra's Avatar
Send a message via Yahoo to Whicked93Cobra Send a message via Skype™ to Whicked93Cobra
Could possibly be the piston return springs wore out or muffler bearings need to be repacked.
As I lay rubber down the street,
I pray for traction I can keep,
But if I spin, and begin to slide,
Please dear God, protect my ride.
Whicked93Cobra is offline   Reply With Quote
Old 01-27-2011, 06:17 PM   #23
i like the piston return spring!!! havent heard that one before, but i have heard the muffler one! lol
Old 01-30-2011, 02:42 PM   #24
Titus Wadicus
svtlx's Avatar
yup...u can find it in haterville. 20 kilometers north of " your just mad cause my stang is faster than yours burg" and 20 kilometers south of "get a life hater"......
Old 01-30-2011, 02:43 PM   #25
Titus Wadicus
svtlx's Avatar
proof gas prices are out of control jimmy_beaner The Bar 56 08-28-2005 06:42 PM
w00t! one small step for me, one giant step for my car fast64 Mustang Audio & Video 5 06-02-2004 01:54 PM
06:34 AM
