engine trouble codes in a 94 gt - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 01-19-2011, 06:59 PM   #1
workmail21's Avatar
workmail21 is unknown around these parts
I got a couple trouble codes that I don't kno what they are can anyone help?
The codes are
116, 632, ego bank one lean bank two lean.
workmail21 is offline
Old 01-19-2011, 08:37 PM   #2
Senior Member
93CobraGuy is unknown around these parts
Re: engine trouble codes in a 94 gt
Check for vaccum leaks or it could be a bad intake gasket. Lean means that you arent getting enough fuel. Your air fuel mixture isnt right and vaccum leaks can cause this to happen. Hope this helps!
93CobraGuy is offline
Old 01-19-2011, 09:31 PM   #3
Senior Member
Straublittleman is unknown around these parts
code 116 is coolant temp sensor and code 632 is transmission control switch did not change state during (KOER) witch would mean you didn't change gears when the test was preformed.
Change the coolant temp sensor and it won't run lean.
Straublittleman is offline
Old 01-19-2011, 11:30 PM   #4
workmail21's Avatar
So if its an auto trans its not shifting right then
Old 01-20-2011, 08:19 AM   #5
Senior Member
No it means at some point in the (Key On Engine Running) test you or who ever didn't shift the gear selector through the gears. It doesn't mean there is something wrong with the tranny, so you are good there but you need to change the coolant temp sensor and reset the computer by unhooking the battery or with a scan tool. Then your car will run right and not lean.
Old 01-20-2011, 09:05 AM   #6
workmail21's Avatar
Oh ok cool thanks a lot for the help
Old 01-20-2011, 09:07 AM   #7
Senior Member
Closed Thread
engine issues... no codes... fuel pump video added jimmy_beaner 1996-2004 Mustang GT 99 05-02-2009 11:56 AM
Check engine light-codes P2197,P2195 The Darkside Pre-2005 V6 Mustang 35 12-11-2008 10:12 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
05:17 PM
