acts like its flooding - Mustang Evolution
Old 01-20-2011, 02:15 PM   #1
I bought a 90 5.0 a couple weeks ago and its acting like its flooding out . It cranks good in the mornings but when the engine is hot I have to hold the gas pedal down a little bit and hope it catches. If not I have to wait for a while to get it to crank. Any help is appreciated , help that keeps me from spending alot of money is really appreciated.
1990foxbody is offline   Reply With Quote
Old 01-20-2011, 02:19 PM   #2
Re: acts like its flooding
my 01 mustang wouldnt idle when it was cold, i would have to hold the gas petal down a bit so it would stay running.
it was the IAC (idle bypass valve) not sure the 90 has the same thing~ also a good maf cleaning is not a bad idea (cheap to do just use electronic parts cleaner NO residue)
Old 01-20-2011, 03:20 PM   #3
MC770's Avatar
I had this exact problem with my 2.3. Not sure what was causing it on mine but we replaced the battery, cleaned the MAF, and put in a new coolant temp sensor and it seems to be solved.
Oh and welcome to ME
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 01-20-2011, 05:38 PM   #4
Thanks I will check that out . Now it just started trying to cut out at low rpm's .
Old 01-20-2011, 05:43 PM   #5
MC770's Avatar
If I recall correctly mine would do the same thing..... Hope those things help
Old 01-21-2011, 07:07 AM   #6
On mine I did the above, sprayed carb cleaner on a rag then wiped inside the TB around the butterfly, then replaced the plugs, cap, and rotor. All fixed
Cobracoupe5 is offline   Reply With Quote
Motor acts like traction control is active ArmyStangGT 1996-2004 Mustang GT 6 09-29-2007 10:42 PM
Little bit of a flooding problem... lowflyn Pictures and Videos 6 04-19-2007 10:18 AM
8th day of flooding Dark02Pony The Bar 6 10-16-2005 12:17 PM
guy in a VW acts stoopid tire The Bar 8 03-27-2004 05:16 PM
» Members Mustangs
GT
Buster
Shadow
Sn95 Jayce
Add your Mustang
01:46 AM
