restoration ? - Mustang Evolution
Old 01-21-2011, 06:23 AM   #1
restoration ?
I am in the process of starting to do a restore/fix my capri.
I was wondering if anyone has used eastwoods rust inhibitor spray? It's easier to do than por15. Also started to rip out that tar sticky Crap that they lay down under the carpet. What is out there that is lightweight to replace that ? I was just thinking bout not replacing it at all.
fivocapri is offline   Reply With Quote
Old 01-21-2011, 06:59 AM   #2
If it's gonna be a race car leave it out. If your gonna be driving the car on the street use dynomat. I did my entire floor board, roof, rear deck, under the back seat, and a little in the doors. It gives the car a nicer ride and makes the car feel solid. If I remember right, It took 2 boxes to do all of that and I'm glad I did it.
Cobracoupe5 is offline   Reply With Quote
Old 01-21-2011, 08:05 AM   #3
Looks good.
Old 01-21-2011, 10:04 AM   #4
Re: restoration ?
good sound deadening goes a long way with sound and heat as well (based on type but most should help against heat as well)
Old 01-21-2011, 11:06 AM   #5
ibleedblue65's Avatar
Seems like it would add a whole **** ton of weight.
ibleedblue65 is offline   Reply With Quote
Old 01-21-2011, 11:46 AM   #6
Re: restoration ?
possibly some weight but you have to decide if the weight is worth the return I guess.
Old 01-21-2011, 06:28 PM   #7
I used 2 boxes to do the entire inside of my car which was 72 sqft and 32.5 lbs total. After removing all the old factory stuff that was hardly adhered after 24 years it really only added approximately 20 lbs evenly across the car. +20lbs for a solid feeling car or -20lbs for a rattle box. I don't know about you guys but I can't stand a car that rattles.
It was worth adding 20 lbs to me.
Old 01-21-2011, 06:30 PM   #8
Thought it would be more than that. Agreed, definitely worth it.
Old 01-21-2011, 07:31 PM   #9
Right now I'm just removing it to see where my rust areas are at. I even found my original factory build sheet. I still have the original door tag/sticker and the build tag thats under the hood.
Old 01-21-2011, 08:36 PM   #10
Re: restoration ?
Nice, I found my build sheet as well on my '84 when I stripped my sound deadening.
93CobraGuy is offline   Reply With Quote
restoration hardware Senorjizzy Pre-2005 V6 Mustang 8 09-22-2009 01:28 PM
restoration help sawing Classic Mustangs 4 11-27-2006 07:50 PM
headlight restoration stang-rookie Pictures and Videos 7 04-05-2006 10:22 PM
headlight restoration red pony V6 Mustang Audio & Video 8 08-29-2005 03:06 PM
'71 Firebird restoration KyleUSAF Pictures and Videos 8 03-27-2005 07:29 AM
04:18 AM
