Best carbureted intake with trick flow heads? - Mustang Evolution
Old 01-21-2011, 07:29 AM   #1
I just installed trick flow 170cc heads on my 302 mustang and would like some input on intake selection! I sold the air gap knock off I had because it was a single plane and I want a dual plane. I stayed with the b-cam in sig but went with 1.72 rockers. Right now the two I'm looking at are the edelbrock 7121 performer rpm vs weiand Stealth 8020. Does anyone have any experience with either or? I wanted to get the edelbrock air gap 7521 but didnt want to spend $250 on it unless there is a noticeable hp increase over the others. If it helps I have a 4" cowl hood so clearance isn't a issue! Please help I need to order my intake asap!
SlyFox512 is offline   Reply With Quote
Old 01-21-2011, 11:17 AM   #2
stampde's Avatar
Re: Best carbureted intake with trick flow heads?
performer RPM ..........
2011 GT Auto
Old 01-21-2011, 01:47 PM   #3
ibleedblue65's Avatar
Why do you want a dual plane? Btw parker funnel web all the way if you can find a real one. Got one on my 347
ibleedblue65 is offline   Reply With Quote
Old 01-22-2011, 11:57 PM   #4
Won't a parker web be too much for
170cc heads and stock displacement ?
fivocapri is offline   Reply With Quote
Old 01-23-2011, 09:08 AM   #5
Possibly but I think with the right cam and carb it will be fine. I run mine with a set off trick flows. It makes great power and isn't a dog down low like you would expect. Although, I do plan to port the heads next time they come off.
Old 01-23-2011, 09:50 AM   #6
stampde's Avatar
dude , its like night and day on the street dual plane to a single , if you swap them out one after the other ( witch I've done before ) the single is a dog down low , sorry thats a fact ...... for his set up ,heads,cam ,the single plane just doesn't make any sense ??
of coarse top end power the single will win out but from idle to about 4,500 the dual will KILL the single in torque and HP / and from 4,500 up to about 5,500 the single will take over but not by a ton, then from 5,500 on the single will Kill the dual , but his cam and head's aren't made for high rpm ... unless your car's a race car stick with the dual plane ,you won't regret it ............
2011 GT Auto
Old 01-23-2011, 09:59 AM   #7
It totally depends on you're set up. I have driven a lit of dual and single plane cars. I have had both on my car. I love the funnel web for power, it makes great power but without the right camshaft it would be worthless.
Old 01-23-2011, 10:34 AM   #8
Your right though, with his set up a dual plane would be better. I guess I didn't read the original post our something
Is anyone running trick flow 190cc heads on a 302? SlyFox512 1979-1995 Mustang GT 1 01-05-2011 12:04 AM
Trick flow top end kit 01 PR RAGTOP 1996-2004 Mustang GT 6 04-19-2010 05:17 PM
Trick Flow Stage 2 clearance joseandmarilyn 1979-1995 Mustang GT 0 04-14-2008 02:00 AM
trick flow valve covers?? bluestang1724 1979-1995 Mustang GT 7 10-01-2007 08:04 AM
Intake Manifold Flow Numbers? snake428CJ 1979-1995 Mustang GT 7 08-14-2007 05:09 PM
12:18 AM
