ROUGH IDLE - Mustang Evolution
Old 07-15-2007, 09:28 PM   #1
ROUGH IDLE
When I first start my car it has a rough idle, but after a bit it stops, but sometimes when im driving and shifting from 1st gear to 2nd it feels its going to shut off and even though I hit the gas it wont go nowhere, it all quits right away. I thought it was my MAP sensor I changed it but it still does it. CAN SOMEBODY PLEASE HELP ME AND AT LEAST GUIDE ME ON WHAT TO DO NEXT.
joseandmarilyn is offline   Reply With Quote
Old 07-15-2007, 09:50 PM   #2
silverstangboy's Avatar
Re: ROUGH IDLE
do the KOEO test and the KOER test...
I wouldn't consider replacing any other sensors until that is done.
DIY KOEO/KOER/Cylinder Balance Self-Test Procedure
sorry for linking to another site brent, but joel is the man.
93 mustang notch
~450hp 331 stroker - Sold
Old 07-16-2007, 05:38 PM   #3
bullitt482's Avatar
Re: ROUGH IDLE
Check the MAF also... Could be REALLY dirty.
01 Bullitt
Old 07-16-2007, 07:18 PM   #4
Re: ROUGH IDLE
I already replaced the MAF,Fuel Filter,MAP, and the car still does it I think it might just be my fuel pump or injectors, because when its on idle and i verly tap the gas it backfires so it might be my fuel pump or injectors.
IF ANYBODY OF YOU GUYS THINK ITS SOMETHING ELSE CAN YOU HELP ME...
THANKS
Old 07-16-2007, 08:22 PM   #5
MonteCitan's Avatar
Re: ROUGH IDLE
if it backfires, it could be either timing or fuel...
Might need the ignition module, or could have an injector stuck open.. could even be a bad vacuum leak or bad evap issue.. check the codes asap... not that they're very accurate in EEC IV
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-22-2007, 08:30 PM   #6
Re: ROUGH IDLE
codes first, check MAF second... BTW a bad maf will usually show up in the memory.
93 mustang notch
Old 07-25-2007, 06:08 AM   #7
Titus Wadicus
svtlx's Avatar
Re: ROUGH IDLE
i'm lean'n towards fuel pump. put a gauge on the schrader valve. if u have to, keep it in the car and check it when the car starts act'n up. some pumps don't start act'n up till their warmed up. just a thought.
Old 09-11-2007, 12:18 PM   #8
Re: ROUGH IDLE
i would check the adjustment of the tps sensor, or the iac valve, mine had the same problem, got the specs from alldata on the tps sensor, and cleaned out the iac and it idles smooth
BADLX5.0 is offline   Reply With Quote
Old 09-27-2007, 11:39 PM   #9
Region: Montana
Re: ROUGH IDLE
If its the same car as the wont start post---the 4 Cyl. that has the timing belt broken then I woulod recheck to make sure your timing-belt marks are right.....just my two cents.
squirt is offline   Reply With Quote
Rough idle upton7 1996-2004 Mustang GT 2 12-14-2009 07:34 AM
rough/surging idle dragonlouie 1979-1995 Mustang GT 25 08-23-2008 07:59 PM
My car seems to idle rellay rough, and miss badly johnpittbull 1979-1995 Mustang GT 21 07-04-2006 09:06 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
MIL P1414, rough idle BlueDonkey Pre-2005 V6 Mustang 7 11-13-2003 11:27 PM
06:28 AM
