Adjustable quadrant cable - Mustang Evolution
Old 01-22-2011, 07:11 AM   #1
Hey guys,
I'm new here. I was wondering if anyone could help with an issue that I'm having with my tranny? I have a '93 gt 5.0 efi car that is set up nice mechanical wise. I bought the car a few months back and haven't really got to step in it but only a couple of times. I've noticed that at higher rpm's , the tranny grinds a bit going into every gear. It has an adjustable quadrant cable on it, and I was told that was the problem, that I need to adjust the cable. I've never done this, and I was looking for some advise.
bizwaks is offline   Reply With Quote
Old 01-22-2011, 08:16 AM   #2
stampde's Avatar
Re: Adjustable quadrant cable
Get under the car ,there's a nut at the end of the clutch cable where it goes through the clutch fork , loosin' the nut till there's no tension , then snug it up till there's tension on it , then tighten it up a few turns , shouldn't take more then a few turns ...... if your still having the grinding issue after that , then you probably have Tranny issues ,most likely syncro's are bad
2011 GT Auto
Old 01-22-2011, 08:39 AM   #3
If the syncronizers were bad, wouldn't it grind when shifting it normal?
Old 01-22-2011, 08:44 AM   #4
[QUOTE="bizwaks"]
If the syncronizers were bad, wouldn't it grind when shifting it normal? It has a hurst short throw shifter as well. Could that play into the problem any?
New quadrant questions Foxone Pre-2005 V6 Mustang 2 07-16-2010 12:58 PM
adjustable clutch cable jt2000gt 1996-2004 Mustang GT 5 12-28-2007 07:43 PM
adjustable springs mitch Pre-2005 V6 Mustang 0 06-09-2007 03:06 PM
Steeda Double Hook Clutch Quadrant For Sale Horse Mustang Parts for Sale and Wanted 10 03-17-2006 10:50 AM
Need help with Clutch Quadrant? 00vertstang Pre-2005 V6 Mustang 5 12-29-2005 05:59 PM
10:15 PM
