Nitrous question? - Mustang Evolution
Old 01-23-2011, 01:33 PM   #1
WhiteCobra94's Avatar
Nitrous question?
Can I used a 75-100hp wet shot with a stock 302 lower end in my 94 Cobra?
Old 01-23-2011, 02:47 PM   #2
I wouldn't see why you couldn't.
93CobraGuy is offline   Reply With Quote
Old 01-24-2011, 10:20 AM   #3
Re: Nitrous question?
you should be ok if the tune is good etc, some shots are RWHP and some are crank so keep that in mind.
Old 01-24-2011, 01:34 PM   #4
Yes you can go a 75 shot without retarding the timing but over that you need to ****** it 2 degrees for 100 shot..3 for a 125 shot and 4 for 150.....150 is max on a stock bottom end and don't do it often. I cruise with the 75 in all the time and bring out the bigger jets for track days. And a wet system is safer than a dry shot
Old 01-24-2011, 01:58 PM   #5
+1
Old 01-24-2011, 02:19 PM   #6
Ok cool , I'm gonna stick with what I first decided with the Edelbrock Performer heads, cam, intake , I just ordered the heads and cam last night and I already have the intake and every other bolt on, I'm not look for crazy power just something fun to drive so I rather put 75-100 shot insteady of a supercharger
Old 01-24-2011, 09:40 PM   #7
94 Mustang GT's Avatar
You can, but i would strongly recommend retarding it more than a couple degrees!
94 Mustang GT is offline   Reply With Quote
Old 01-25-2011, 04:29 AM   #8
I have a friend that runs a 150 shot like its gasoline through his stock bottom end 302. Drop the timing 4 degrees or so and run a colder heat range spark plug. That should alleviate any major issues. Just dont forget that every motor is different and yours may react very differently than any others.
Vendetta is offline   Reply With Quote
Old 01-25-2011, 09:50 AM   #9
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
Running a 75 shot in mine...you should be good!
Chick Nasty is offline   Reply With Quote
Old 01-25-2011, 10:15 AM   #10
stampde's Avatar
75 not a prob , i've run 150 thru some engines with stock bottom ends and never had a prob / well except for the time i juiced a cast piston 351w and melted some pistons, lol
2011 GT Auto
Old 01-25-2011, 01:53 PM   #11
so maybe i couldl boost up to a 100 shot ...stock bottom end 4.6?
Old 01-25-2011, 09:53 PM   #12
Yeah for sure, but definitely use higher octane gas!!
Old 01-26-2011, 06:41 PM   #13
Yes ....for 100 shot you have to ****** timing as well or fill up with 110 octane...I have an ais meth kit that sprays the same time my nitrous so I don't have to ****** timing at all....before that I was mixing 1lier of toluene with a half tank of fuel to bring octane on the tank to well over 100 and that eliminated any chance of detonation. I have a 4.6 liter engine and it was alot of trial and error on a deserted highway to figure out timing ******. I suggest using your tuner and starting with -5 degrees timing and running it til you find your sweet spot. And I have a zex kit. I bought it off eBay real cheap but it only came with a 55/65/75 hp jets. I bought the 100/125/150 separate....on the street up to 75 hp doesn't need any timing ****** but 100 does...I found out the hard way...buy a meth kit and you don't need to ****** at all. And at wot add 4 so you get ample fuel for the nitrous to burn up. Just that alone was good for 2/10ths in the quarter
Old 01-27-2011, 10:26 AM   #14
Now I'm only using 24lb injectors! Does that have anything to do with what size jets I'm gonna use , most likely for now it's only gonna be a 75-100hp shot
Old 01-27-2011, 10:44 AM   #15
Nope...the stock fuel system can handle up to about 200 but the bottom end is in question when going that big. The key is using your tuner and adding fuel at wot. Start at + 6 and work your way down til you find it pulls the hardest...I found a 2 lane highway just outside the city to do my trial and error. I found that at 150 plus 6 pulled the best and wasn't too rich. At a 100 shot plus 4 would be close. I am spraying meth now so the fuel system has less to compensate for.
nitrous
nitrous question gambit90lx 1979-1995 Mustang GT 10 08-24-2007 07:59 AM
nitrous question? ryanxup Pre-2005 V6 Mustang 2 09-28-2006 07:44 AM
v6 nitrous question blk2kconvstang Pre-2005 V6 Mustang 8 03-02-2004 07:01 AM
Nitrous Question 02whitestang Pre-2005 V6 Mustang 6 12-11-2003 07:46 AM
Nitrous Question ponyboy1995 Pre-2005 V6 Mustang 5 10-13-2003 09:40 AM
08:53 AM
