tires - Mustang Evolution
Old 01-26-2011, 06:22 AM   #1
A.K.A. Baby-D!
tires
Hopefully should be buying new tires for my 88 fox soon. Just wanted an opinion on which kind to get. I would like to get something good for street & track as I hope to get her to the track soon. Hoping not to spend a fortune, but if i have to I’ll put it off for a while so I can save up for the right ones.
So what do you recommend and what kind of experience you’ve had with certain tires?
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 01-26-2011, 08:51 AM   #2
Re: tires
what rim size
Old 01-26-2011, 08:55 AM   #3
A.K.A. Baby-D!
Re: tires
i need to check and make sure but i think like 17x9 or 17x8
Current:
Previous:
Old 01-26-2011, 09:00 AM   #4
Re: tires
if its one or the other tires should be around 80-110 each. I would compare on Home - Discount Tire Direct and then call em and see what kind of deal they can work up, they are good to work with. They gave me free road hazard on a set of tires... and I had to replace two of them a week apart. They didnt ask any questions and shipped me a new tire free of charge. Also, when the tires wore out early they prorated my new tires based on miles they should have got.
Old 01-26-2011, 09:05 AM   #5
A.K.A. Baby-D!
Re: tires
thx thats real good to know
Current:
Previous:
Old 01-26-2011, 09:07 AM   #6
Re: tires
Nittos would be a good idea. A lot of people have had good luck with the NT05's from them. They are a good street tire but are sticky enough to hold launching on stock 03/04 cobras. Don't get the drag radial version tho as they are not good in rain.
I had great results from the nitto 555's when I had my GT as well. It would do well on the street and hold good enough at the track.
Old 01-26-2011, 09:13 AM   #7
A.K.A. Baby-D!
Re: tires
thx! thats what i need to hear. the car wont see rainy roads much.. just need that nice launch on the track with street use on good days
Current:
Previous:
Old 01-26-2011, 09:18 AM   #8
Re: tires
If it's for nice days only, you could look at nitto 555R drag radials or the new nitto NT05R drag radials. The 555R's will last you about 15-20k miles depending on the number of burnouts you do. The NT05R's will last you about 5-10k miles depending on the burnouts but will stick a lot better than the 555R's will.
I was able to get about 15k out of a set of 555R's when I had them on the cobra. I had those on there twice and got around 15k out of each set.
I had 30k on a set of regular 555's on my GT but did a ton of burnouts on them so they were down to about 30% tread left. I had over 30k miles on the set I put on the cobra, but those were just in the front, so that doesn't count.
Old 01-26-2011, 09:24 AM   #9
A.K.A. Baby-D!
Re: tires
thx! great information! i'm gonna go look up prices, but which do u feel is best bang for the buck?
Current:
Previous:
Old 01-26-2011, 09:29 AM   #10
Re: tires
For the fox, I would go with the 555R's. You'll get decent life out of them for the type of tire, and you'll get decent traction as well. And if you do get caught in a freak rain, you'll get better traction than the NT05R's would.
If you're just not concerned about the track all that much, I'd go with the regular NT05's though. You'll get a little more life out of them at a little cost of traction over the 555R's...but they will run you about $40 or so more per tire than the 555R's.
For the fronts, I would just get the regular 555's or NT05's though. I have the regular NT05's on the front of my car right now...and have run the 555's before. Either will work great. You'll get a little more road steering from the 555's due to the direction tread...but it is a good tire.
Old 01-26-2011, 09:30 AM   #11
A.K.A. Baby-D!
Re: tires
from what i'm seein on discount tire direct, 153/ea for 555rs and 177/ea for nt05rs (estimate size i would need)
i think i would rather go with the 555rs. can they be used all around the car?
Current:
Previous:
Old 01-26-2011, 09:31 AM   #12
A.K.A. Baby-D!
Re: tires
you read my mind. thx so much for the input!
Current:
Previous:
Old 01-26-2011, 09:32 AM   #13
Re: tires
No, get the regular 555's for the fronts. You "could" use them in the front, but there really is no need to and with the soft compound you would wear them down real fast. The regular 555's are a much harder compound.
Old 01-26-2011, 09:35 AM   #14
A.K.A. Baby-D!
Re: tires
ok i'm looking at the 555r's in rear and 555's up front.
thanks so much!
Current:
Previous:
Old 01-26-2011, 09:38 AM   #15
Re: tires
I think you'll like those. I did on the cobra when it was stock. They would break loose a bit at street pressures, but that was 35 psi. When I lowered it down to around 30 psi, it got much better. But then I did a pulley swap....and then I did a ported blower swap and the closer I got to 500 hp the less they would hold.
The fox...they should hold plenty fine.
Old 01-26-2011, 09:40 AM   #16
A.K.A. Baby-D!
Re: tires
yea. don't plan to see those kind of numbers in the fox anytime soon for sure. the tires will probably be gone by then. lol
Current:
Previous:
Old 01-26-2011, 11:59 AM   #17
A.K.A. Baby-D!
Re: tires
not looking good. i'm currently running 255/40/17 all the way around. wouldn't mind going a little skinnier in the front. def. can't go taller.
for the 555's they have the 255/40/17's like i need.
for the 555r's the closest they have is 275/40/17... not sure if i can squeeze that size tire in the rear. anyone with a fox body know if this will fit?
if not i guess i would get the 555's all around and buy a pair of rims with drag radials for the track. unless i find another kind of tire i like with right size.
Current:
Previous:
Old 01-26-2011, 02:31 PM   #18
A.K.A. Baby-D!
Looked around more. They have the nt-01 drag radials in the size I need. I just don't know if it would look ok having the 555s up front. The 555r has a similar pattern even thought it's considered drag radial.
Opinions?
Current:
Previous:
Old 01-26-2011, 10:20 PM   #19
Re: tires
You don't want the nt01s. Nt05s ok, but not the 1s.
Nitto dr's will run narrower than other brands tho so you should be good for width. It's the extra height that may be an issue.
Old 01-26-2011, 11:41 PM   #20
A.K.A. Baby-D!
They have the 555r in 275/40/17. The guy from Nitto said it may not fit on 17x8s. Idk if I should chance it or not
Current:
Previous:
Old 01-26-2011, 11:57 PM   #21
Re: tires
I had the 315s on my 17x9 and they didn't bulge much at all.
Old 02-02-2011, 06:49 AM   #22
A.K.A. Baby-D!
Re: tires
well i went ahead and ordered the 275/40/17 555r drag radials for the rear. the 555's for up front will have to come next paycheck... can't wait to have them all mounted
thx again for all the tips & advice!
Current:
Previous:
Old 02-02-2011, 11:37 AM   #23
bbunt302's Avatar
Re: tires
The 275/40/17s will fit a 17x8. Nitto tires run extremely narrow. I personally wouldn't have recommended the 555Rs, however. Your best bet though is to stop trying to find a tire that works well for both the street and strip. I had a set of 555Rs on my car for a while and they were not worth the money. The BFG drag radials I had previously did a much better job at launching than the 555Rs. The 555Rs were barely better than your average street radial. Problem with the BFGs is that they only get about 5k miles or so before they are too worn to use.
Just get a spare set of wheels and a set of slicks for the track. You'll save money in the long run because of how fast the 555Rs are going to wear out.
Scary stuff.
Old 02-02-2011, 12:35 PM   #24
A.K.A. Baby-D!
Re: tires
wish you would have chimed in beforehand..lol
well i will see how it goes with the 555Rs. i do plan to get a spare set later on, so i'm sure that's what will happen eventually. just wanted something i could enjoy in both places. my fox doesn't see many miles.
Current:
Previous:
Old 02-02-2011, 02:52 PM   #25
MC770's Avatar
Re: tires
Since your getting new tires you should smoke the old ones that are on it
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 02-02-2011, 02:59 PM   #26
I'm running 555's in front and drags in back. Just stay away from water. **** gets scary.
Alscobra is offline   Reply With Quote
Some might like this. Got new tires sonic04edge Pictures and Videos 14 07-24-2009 09:53 PM
tires??? bluestang1724 Mustang Wheels & Tires 30 05-03-2006 06:08 PM
cobras/tires for welds/tires, $$$? tire The Bar 2 02-22-2004 11:11 AM
10:29 AM
