Got some new fans - Mustang Evolution
Old 01-29-2011, 11:05 AM   #1
Mike90's Avatar
Got some new fans
Got some fans from PAP. Wich set should I use ??
The single leaves about an 1" gap on each side.
The duals fit perfect.
They say the good die young,
I plan on living forever!!
Mike90 is offline   Reply With Quote
Old 01-29-2011, 02:07 PM   #2
Re: Got some new fans
The dual fans will draw more current I think. I had a single on both my '84 and '85 and it seemed like more than enough to keep em cool!
I'd stick with the single, unless you have upgraded your alternator. Just my $.02.
93CobraGuy is offline   Reply With Quote
Old 01-29-2011, 04:55 PM   #3
1ijack's Avatar
Send a message via Yahoo to 1ijack
I would stay with the single unless you upgrade the alternator too. I like the dual fans but you know the old saying if it aint broke don't fix it. in my opinion.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 01-30-2011, 11:19 PM   #4
SleepingStang's Avatar
I had the dual Taurus fan that you show installed on mine. I also have the 3G upgraded alt. With the 3G installed the lights would not even dim when they kicked on. Depending on what fan controller you use different voltage spikes can be expected. I believe that the dual Taurus fan if allowed to kick both fans on at their max speed will draw something like 40 amps. Some controllers such as the Delta Current Controller will allow the fans to kick on at a lower speed and ramp up, essentially stopping spikes in amps. I am not positive but I think the top fan in your photo is a Lincoln mark VIII fan. If it is that fan it will draw more amps than the dual Taurus fan, it also moves a ton of air. When I had the Taurus fans in I had no problems with cooling. I removed them because I went another way. I will tell you to make sure that either fan is securely mounted. These fans have a ton of torque, if you want to see what I mean hook a battery to one of the Taurus fans. Either fan is a good choice but I would without a doubt upgrade the alternator or you may end up frying something else in the car when those fans kick on.
SleepingStang is offline   Reply With Quote
Buckeye fans hottcobra The Bar 0 12-18-2007 04:57 PM
Any Final Fantasy Fans or Need For Speed Fans Justin The Bar 34 11-07-2006 11:44 AM
For those 2pac fans Dark02Pony The Bar 2 12-05-2005 12:16 AM
any CS fans? Thomas91169 The Bar 2 01-29-2005 07:47 AM
Sox Fans Ken The Bar 5 10-20-2003 09:27 PM
12:29 PM
