Trick Flow engine upgrade kits - Mustang Evolution
Old 01-31-2011, 04:05 PM   #1
Albaraptor's Avatar
Does anybody know how much hp and torque the track heat or street heat kits give u?
Albaraptor is offline   Reply With Quote
Old 01-31-2011, 06:11 PM   #2
1ijack's Avatar
Send a message via Yahoo to 1ijack
Re: Trick Flow engine upgrade kits
When I talked to some different people wjhohave used the trick flow setup. 190 Heads, trach heat intake and trick flow cams. I have heard as little as 75hp and 125 hp.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 01-31-2011, 06:51 PM   #3
Albaraptor's Avatar
So 300 plus total
Old 02-01-2011, 01:25 AM   #4
1ijack's Avatar
That is dropping alot of money into your stang. 1900 for the heads, 900 for the track heat intake, 900 for the cams, they recommend their fuel rails, injectors, new throttle body, new mounts for the alternator. then I haven't got install prices compared to me doing it. It is a great investment then you can add the juice to it.
The Mustang Mafia
Old 02-01-2011, 04:33 AM   #5
Albaraptor's Avatar
I can get the whole kit for 2599 at cj pony parts
Old 02-01-2011, 08:15 AM   #6
93slowstang's Avatar
You can probably get it a few hundred dollars cheaper through LRS
Old 02-02-2011, 06:24 PM   #7
silverstangboy's Avatar
I don't think its a bad kit, if I remember right it doesn't come with roller rockers, so I'd ditch the factory and go with 3/8" studs and get the correct length pushrods on custom order... thats probably why so many people report a large variance in power gains.
93 mustang notch
~450hp 331 stroker - Sold
Old 02-03-2011, 05:36 PM   #8
Titus Wadicus
svtlx's Avatar
my gosh that's alota money, seems like your in supercharger price range at that point..idk......
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-03-2011, 05:58 PM   #9
Albaraptor's Avatar
Yeah but if I do this then put a vortech on watch out
Old 02-03-2011, 06:10 PM   #10
Titus Wadicus
svtlx's Avatar
if you just put the vortech on...they still have to watch out. im not sayng dont do the h/c/i kit. but must ppl are happier with the blower first, most bang for your buck if you got a choice between the two. if your plan'n on runing boost, build around the blower, not the other way around.
you will be happier in the long run, you will prolly choose a different head with lower compression ratio, and definatley a different cam if you are gonna run a blower. versus a n/a set-up.
a boost specific h/c/i combo will net you more hp in the long run if boost is your plan..
Old 02-03-2011, 06:12 PM   #11
Albaraptor's Avatar
Thanks for the info what kinda hp range with going with the blower first without the other
Old 02-03-2011, 06:28 PM   #12
Titus Wadicus
svtlx's Avatar
it all depends on how much boost you throw at it. 45-65 @5-6psi..possibly 75-100hp @9-10psi. that's what the blower companies say. but there are alot of variables even with a most stock motor. such as the mass air meter (huge factor), are you using an fuel managment unit or correct size injectors for boost level.
its best to decide on a hp range you wanna be at, how streetable you want the car to be, and then start building around that hp level.
when i started my goal was 400hp...now it's 500. however, there are trade -offs for the power, fuel milage, type of fuel you can use, 450-500 at the wheels sounds great on paper, till you try to drive it daily...everyone is different. my car is an adventure to drive on wet pavement...i try to watch the weather now..lol.
Old 02-03-2011, 06:32 PM   #13
Albaraptor's Avatar
I'd like to get about 400-450 when I'm done with it
Old 02-03-2011, 06:40 PM   #14
Titus Wadicus
svtlx's Avatar
well im doing 456 at the wheels with standard stroke and ported heads @11psi. are u on an i-phone? if not you should be able to see my signature with my set-up. i have a fairly budget set-up. im gonna move up to about 14psi, possibly get a tune, then call it a day. i think im ay get 475-490 when it's all done and said.
you got a very attainable goal, without alot of effort on your part.
Old 02-03-2011, 06:42 PM   #15
Titus Wadicus
svtlx's Avatar
honestly, i think you could get that with a good blower cam, mass air, intake...and a tune. and matching injectors...fmu's are for beginers...
Best carbureted intake with trick flow heads? SlyFox512 1979-1995 Mustang GT 7 01-23-2011 10:34 AM
Is anyone running trick flow 190cc heads on a 302? SlyFox512 1979-1995 Mustang GT 1 01-05-2011 12:04 AM
Trick flow top end kit 01 PR RAGTOP 1996-2004 Mustang GT 6 04-19-2010 05:17 PM
Trick Flow Stage 2 clearance joseandmarilyn 1979-1995 Mustang GT 0 04-14-2008 02:00 AM
trick flow valve covers?? bluestang1724 1979-1995 Mustang GT 7 10-01-2007 08:04 AM
05:02 PM
