How to tune turbos - Mustang Evolution
Old 01-31-2011, 10:39 PM   #1
How to tune turbos
I'm gonna buy a twin turbo for my fox and I wanna know how to tune them. Any ideas??
Hyphynator is offline   Reply With Quote
Old 02-01-2011, 02:03 AM   #2
Ya...take it to a dyno tuner. That is some complex stuff and if you don't know do you really want to risk your engine. They have to custom write the fuel maps due to how much boost at all rpms. I would take that "investment" to a profesional
Old 02-01-2011, 07:24 AM   #3
Re: How to tune turbos
most dont know enough to tell you how to tune, and by your question I assume you dont either. Thats why its far better to leave it up to a professional that has experience with your type of car and turbo setups. Might cost more... but might be cheaper than a rebuild with a bad tune
Old 02-01-2011, 07:05 PM   #4
Tuning is not that bad I swapped in an 84 svo engine and tranny into my pace car and used a megasquirt for engine management and it is mostly stock engine except for an to4e turbo and 16 psi 60 lbs injectors a frontmount intercooler and upgraded exhaust I can walk mildly modded cameros all day. It just takes a bunch of time and patience.
Turbo_Raccoon is offline   Reply With Quote
Old 02-02-2011, 06:39 PM   #5
silverstangboy's Avatar
yeah, the answer to that question is an 80 hour training course that would only get you started and dangerous.
take it to a pro.
93 mustang notch
~450hp 331 stroker - Sold
Old 02-03-2011, 02:52 PM   #6
Titus Wadicus
svtlx's Avatar
the simple fact that you are asking the question means you should definatley take it to a tuner. every car and set-up is different.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-04-2011, 07:14 AM   #7
its great to want to learn how and to go and do so, just dont do it on your car lol
? about twin turbos Z-EATER 1979-1995 Mustang GT 5 08-22-2007 08:58 PM
Got My New Turbos bluemustang Pictures and Videos 10 06-18-2007 09:28 AM
How many turbos can you cram...? HotRod.riguez General Mustang Discussion 73 05-14-2007 03:26 PM
8 Turbos DarkShadow The Bar 13 10-23-2005 09:55 PM
Talkin Turbos n8r Pre-2005 V6 Mustang 9 01-17-2005 01:09 AM
10:48 AM
