turbo or supercharge - Mustang Evolution
Old 02-01-2011, 01:23 AM   #1
hello everybody i was wondering i anyone can help me i have a 1989 mustang gt 5.0l im and i have a lot of plan for it but the first question i havent decide to go for a supercharge or turbo.because im getting all the parts together for summer but i cant decide.thanks.
Alexis0517 is offline   Reply With Quote
Old 02-01-2011, 01:48 AM   #2
I replied to your other post.
Alscobra is offline   Reply With Quote
Old 02-01-2011, 01:48 AM   #3
Turbo. I like them due to the fact that it's spun via your exhaust therefore "free" power and a supercharger runs off your crank and there is parasitic loss. A turbo tends to build a very flat torque curve which is nice. If you go supercharger a kenne bell or tork teck is the type I would suggest. I like that they are bolted right to the top of motor and get into boost very fast. No matter which you choose you are gonna be one happy camper.
Old 02-01-2011, 01:58 AM   #4
Re: turbo or supercharge
There's a lot of people here who seem to like turbos. I've always done chargers. They really don't take any real hp to turn them. Your a/c compressor takes more power to turn. I don't like the idea of re-routing and restricting exhaust systems. If u r gonna force air in u gotta let it out as quick as possible.
Old 02-01-2011, 05:30 AM   #5
Good point. There are pros and cons to each.
Old 02-01-2011, 07:21 AM   #6
both have advantages and disadvantages. You need to be realistic with what your budget it and if you can afford to blow up the motor and rebuilt it etc etc (basically you are ok if it breaks down the line)
a turbo will give more power and more performance but will cost more
Old 02-01-2011, 07:56 PM   #7
I have a single turbo on a four cylinder mustang engine that thing is my daily driver at 15-16 psi and it loves the boost I don't have any issues with it and I wouldn't go any other route but a turbo but that is just me I hope this little info helps.
Turbo_Raccoon is offline   Reply With Quote
Old 02-03-2011, 05:31 PM   #8
Titus Wadicus
svtlx's Avatar
i run a supercharger, i prefer them of turbos. at the end of the day, you could prolly make more hp with a turbo...but how much are you willing to spend to get it. i think turbos cost more in initial investment also. unless your "real good friends" with a good pipe bender.
there are alot of pros and cons for both, it's really bout personal preference and how much are you willing to spend to get it off the ground. to do it right, a motor set-up for boost tends to be a lil different than a n/a motor.
if your on a budget, i think everyone here can agree that stock low compression heads and a stock cam can save you alot of grief and be your best friend if your new to the world of boost. regardless if you go turbo or supercharged
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-06-2011, 02:24 AM   #9
well thanks for all the reply i was wondering i anybody can send me a web pages were i can find a decent turbo i think that what im going for my budget is 3000
TURBO CHARGE or SUPERCHARGE usmc_berkeley 2011-2014 Mustang GT 10 12-23-2009 02:11 PM
Supercharge a Stock 302 Justin 1979-1995 Mustang GT 27 01-23-2007 08:03 AM
94 Mustang GT Supercharge T56 6spd rwd121874 Mustangs for Sale and Wanted 4 12-04-2006 08:26 PM
supercharge and turbocharge differences cmanzi79 General Mustang Discussion 7 01-18-2006 11:58 AM
GTO or Supercharge GT?? douGT The Bar 20 06-19-2005 09:16 AM
04:11 AM
