Clutch noise?? Please help! - Mustang Evolution
Old 02-01-2011, 05:13 AM   #1
Ok so I was driving back from San francisco and then started hearing this noise every time I step on the clutch. Anyone know what it is?? I have a stage 3 clutch with the TREMEC 3550 with Lucas automatic oil ( which I was told to use, but I've hear synchromesh is better) pro5.0 short shifter and an aluminum drive shaft. PLEASE HELP NEED TO SELL VERY SOON.
ID:	23135   Click image for larger version
ID:	23137   Click image for larger version
Hyphynator is offline   Reply With Quote
Old 02-01-2011, 08:22 AM   #2
Re: Clutch noise?? Please help!
what noise are you hearing, is it only when you first start pushing in the clutch then it goes away, does it happen letting out the clutch etc? Can you be more descriptive.
Old 02-01-2011, 09:31 AM   #3
Just a guess I would say without hearing it that it could be the throwout bearing
Old 02-02-2011, 11:46 PM   #4
Is it a squeal? Describe the sound and exactly when it makes the noise.
Cobracoupe5 is offline   Reply With Quote
Old 02-02-2011, 11:54 PM   #5
Well the noise is every time I push on the clutter. And I soon as I let it go the noise is gone.
Old 02-02-2011, 11:57 PM   #6
I'd say bad throw out bearing.
Old 02-04-2011, 02:31 PM   #7
How long would it take to replace??
Old 02-04-2011, 04:24 PM   #8
if its when you push in the clutch petal then as said if its a squeek, tick, etc type sound its probably the pilot bearing or throwout bearing. Its a cheap part.... but requires the trans to come out to get to it. While its out is a VERY good idea to replace the pilot bearing and inspect everything, if miles are anything over like 20k might as well change the clutch while your at it lol.
Before you do all that try taking up adjustment in the stock cable to buy you more time. If its an OEM clutch quadrant then just push the seat back put your left hand on the clutch and your right hand on the quadrant (after you push the clutch to the floor). The quadrant is white and above the gas petal, you will see the clutch cable over it. Slowly ease out the clutch while holding tension on the clutch quadrant. You cant stop it from turning but you can put pressure on it to hold it back where it was when the clutch was pushed in to the floor. As it gets closer to being all the way out (the clutch petal) you will hear a click. Do a couple clicks. This will start to take up slack in your clutch cable. The petal will be firmer and higher up. Drive the car after two clicks. The car should not slip. To test for slipping have the gas held steady with your foot and slowly push in the clutch while driving like 45mph or so. If you can push in the clutch half an inch from the top where you start before the rpms start to jump up then its ok. Any less is to tight they say.
Adjust as needed to get the top of the petal firm etc. To unadjust simply lift up on the underside of the clutch petal.
Old 02-04-2011, 05:45 PM   #9
Old 02-04-2011, 06:06 PM   #10
Depends on how long it would take you to drop the transmission out. Just like SpectorV said, if you drop the tranny, you might as well replace the whole clutch kit, including throwout bearing, and pilot bearing. I've dropped so many transmissions its not even funny, I can have one on the ground in about 45 minutes.
93CobraGuy is offline   Reply With Quote
Old 02-04-2011, 06:19 PM   #11
From experience get the car as high as you can and you need a swivel fitting and alot of patience
Old 02-05-2011, 12:59 AM   #12
I've done it in 2 1/2 hours with a friend helping me but it's one of those projects that while your down there, you might as well do a few other things like the pilot bearing, clutch, and inspect the flywheel too. It really sucks having to do all that work twice just to save a buck. If money is tight I guess you have to do what you gotta do.
Clutch noise jldusza Pre-2005 V6 Mustang 7 09-16-2010 08:17 AM
strange clutch noise R1CK3R Pre-2005 V6 Mustang 10 10-02-2009 11:47 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-30-2008 12:24 AM
Weird noise electricstang Pre-2005 V6 Mustang 17 06-20-2006 07:29 AM
Brake noise megax29 Pre-2005 V6 Mustang 1 05-07-2006 11:32 AM
02:59 PM
