Cam and pushrod prob. - Mustang Evolution
Old 02-06-2011, 05:27 PM   #1
Hi, I replaced my cam, lifters and pushrods in my 302 and the new pushrods are shorter then my old ones and the rockers have play in them. How can I fix this problem. The old pushrods put pressure on the springs any advice would be great thanks.
Dexter is offline   Reply With Quote
Old 02-06-2011, 08:58 PM   #2
Re: Cam and pushrod prob.
Did you have it measured to see what length you needed?
I'd recommend having someone who knows how to measure for the right rods take a look at it for you. It definitely won't run with the longer rods.
Old 02-06-2011, 09:23 PM   #3
Titus Wadicus
svtlx's Avatar
im wondering if the lifters are shorter? check the length of the old lifters over the new, most likely that is your difference. if u try to use the old lifters and pushrods, u may change the valve lift when it is in opersation. when i changed rocker arms i had the same problem. i ended up having to use "+.117 over stock" pushrods. they have pushrod length checkers they sell in a set at jegs and summit. it basicly a set of blank pushrods, you keep goin one size up till u find the one u need, and that's how u figure the correct length you need. i used a screw driver and wedged it in over the stock push rod and under the rocker arm to calculate/measure the length i needed. whichever works...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-06-2011, 10:06 PM   #4
The lifters are the same size but the pushrods are shorter. Can you awnser me one thing, when using the proper pushrods and the valve closed will the rocker compress the valve spring a bit when you tighten the rocker bolt?
Old 02-07-2011, 12:15 AM   #5
You could buy a set of adjustable rockers 1.6 or 1.7 roller and adjust them so you have no play.
Straublittleman is offline   Reply With Quote
Old 02-07-2011, 10:01 AM   #6
Titus Wadicus
svtlx's Avatar
it may a tiny bit, but shouldnt do it much if the valve is closed. my next question is this? do you have pedestal stock type rocker arms or stud mounted? honestly you need to contact the company you bought it from if it's a set. have you tried putting your stock pushrods back in?
if you installed your old pushrods and they seem to fit snug.... i would advise you to clay pistons tops re-assemble it. roll it over a few times(by hand) and double check that you dont have any piston to valve issues before operating the engine with those pushrods.
im really curious if your using pedestal or stud mount though
Old 02-07-2011, 10:27 AM   #7
stampde's Avatar
you have the wrong P-rods ,take then back and get the right ones , easy enough
2011 GT Auto
Old 02-07-2011, 09:20 PM   #8
+1 and adjustable roller rockers would be a good idea too.
What kind of heads are you using?
Cobracoupe5 is offline   Reply With Quote
Old 02-07-2011, 09:30 PM   #9
I'm using stock heads with stud mount non adjustable rockers, the guy I bought them from was using adj rockers I didn't know that until this morning. So I gonna have to get adj rockers but the conversion is not worth it to do with all the machine work and parts buying, I might as well invest in some aftermarket heads. Thanks to all you guy for helping me, that's why I come here.
Old 02-07-2011, 09:55 PM   #10
Titus Wadicus
svtlx's Avatar
and thats y i asked if you had pedestal or stud mount. you could prolly pic up a set of 1.6 or 1.7 pedestal mount for a 150-200 bucks. i been using a cheap set of 1.7 proforms for several years now i bought off of ebay. depending on the brand of rocker you get, you can still run into the pushrod length issue. its just kinda par for the course so to speak, even with pedestal
Old 02-07-2011, 10:52 PM   #11
A lot of people run the ford alphabet cams so they can use the stock prods and rockers. When I put the e cam in my wifes car everything fit perfectly.
Old 02-07-2011, 11:11 PM   #12
When you say everything fit you mean stock pushrods and rockers?
Old 02-07-2011, 11:21 PM   #13
Titus Wadicus
svtlx's Avatar
you dont have to get an alphabet cam for you to use stock pushrods and rockers. just do sum research before you buy...but fuk it, all else fails, get an alphabet. i run an e-cam..but i use 1.7 rockers.
Old 02-07-2011, 11:34 PM   #14
I used the stock push rods and rockers with no problems about 100k miles ago. She has about 250k on her 90 coupe now with no problems. You can use other cams as long as they have the same base circle as the stock and alphabet cams.
Old 02-08-2011, 08:48 AM   #15
Thanks again you guys, it turns out that stock length pushrods work cus the base circle is the same. You guys are pretty smart
Old 02-08-2011, 07:25 PM   #16
Your welcome!
Old 02-08-2011, 10:09 PM   #17
silverstangboy's Avatar
just to reiterate, no, at the base of the cam you should see no spring compression at all, that is of coarse BEFORE you do the 1/4"-3/4" preload turn.
getting adjustable rockers won't fix the problem with the pushrods, I suggest you get an adjustable pushrod checker and convert one of your lifters to solid to do a length test.
here is the procedure on a dart head, it is the same for SBF
once you get the right measurement order a custom set of that length.
as far as the pedestal mount rockers, ford makes shim kits for this perpose to raise the rockers, and I have been known to grind the pads down to get them right as well, the video doesn't say to but getting a thin marker line is the most important, being slightly off to one side or the other is OK so long as the wear line isn't WIDE.
people leave alot of power and engine longevity on the table because they generally don't bother to get this right. I have seen a set of heads get ruined in 5-10K miles because the geometry was set up so bad.
93 mustang notch
~450hp 331 stroker - Sold
Old 02-09-2011, 10:09 PM   #18
Now that is some backyard ingenuity. Nice idea
Old 02-09-2011, 10:13 PM   #19
Titus Wadicus
svtlx's Avatar
cheaper than the pushrod length checker set at jeg's...ive got tons of screw drivers...lol.
Old 02-09-2011, 10:51 PM   #20
What cam are you running? You may just need stock length prods but I would at least get a set of hardened ones.
Alscobra is offline   Reply With Quote
Old 02-09-2011, 10:57 PM   #21
Titus Wadicus
svtlx's Avatar
he figured out his problem a couple days ago...we're just running this thread into the ground...lol.
Old 02-09-2011, 11:13 PM   #22
Run it down.
turn signal prob gearbanger67 Classic Mustangs 2 10-09-2007 08:37 PM
Pushrod length snake428CJ 1979-1995 Mustang GT 1 08-13-2007 09:12 PM
weird prob bluemustang ME Site Help & Announcements 5 11-13-2006 09:07 PM
prob old but funny video Dark02Pony The Bar 1 01-08-2006 10:34 PM
pushrod length 89'FIVE-O 1979-1995 Mustang GT 5 09-17-2005 12:11 PM
09:45 PM
