About my exhaust mid-pipes? - Mustang Evolution
Old 02-06-2011, 08:29 PM   #1
WhiteCobra94's Avatar
On my 94 cobra I have Bassani x-pipes with cats, but I wanna go with the off-road x-pipes, question is can I cut out my cats that I have now and use that as off-road or no? Should I just buy the off-road x-pipes? Thanks
Old 02-06-2011, 09:07 PM   #2
Titus Wadicus
svtlx's Avatar
Re: About my exhaust mid-pipes?
when i had my tbird i just beat out the material with a really long pry bar. but if you can spare a couple hundred bucks just buy an off-road x and get it over with.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-06-2011, 09:55 PM   #3
93slowstang's Avatar
If it has high flow cats on it I wouldn't even worry about taking them off. They flow just as well as an off road x-pipe.
Old 02-06-2011, 10:04 PM   #4
Yea there highflow cats, .... I still fail my emissions with them but I keep it under 5k a year so I get exempt now every year
Old 02-07-2011, 03:58 PM   #5
Well you could have them cut out, but it would probably cost almost as much as a new one so i would just buy a new one if your that worried about it.
Old 02-07-2011, 05:24 PM   #6
Well is there a noticeable difference between the high flow-cats and off-road ones, I'm doing my HCI swap and just just Bassani headers, , I'm trying to figure out if it's worth changing the mid-pipes or not!!
Old 02-07-2011, 05:57 PM   #7
I have a bassani 5 piece x pipe on the cobra. When I bought it the high-flow cats were in place and I pulled them out and put pipes in their place. Honestly...it made very little sound difference and I imagine zero power difference.
If you just want the option look into selling your x pipe and buying one of the 5 piece units where you can remove them with ease.
Old 02-08-2011, 10:48 AM   #8
I have to agree with lowflyn it isn't going to make a noticeable difference if any with the sound or hp.
Old 02-08-2011, 10:50 AM   #9
Ok cool I'm just gonna stick with the bassani high flow-cats for now!
exhaust
Which Mid Pipes To Go With???? Gt.Vert 1996-2004 Mustang GT 12 02-18-2010 08:29 AM
mid-pipes and o2 sensors eddie1 1996-2004 Mustang GT 2 12-03-2009 10:49 PM
Question about mid pipes GTCS4ME 2005-2010 Mustang GT 3 11-26-2009 09:15 AM
Pypes Mid Muffler Exhaust Tompkins 2005-2010 Mustang GT 12 10-14-2009 03:32 PM
mid pipes 96-98 GT silverstangboy Mustang Parts for Sale and Wanted 1 12-15-2006 05:31 PM
10:14 PM
