4.10 gears autp tranny - Mustang Evolution
Old 02-10-2011, 10:20 PM   #1
Schlahty's Avatar
Region: Oregon
94 5.0 with 60000 mls. 4.10 gears 4 speed automatic transmission. Tranny slipped before gear swap. Went little too low on gears. Figured with twenties and large tires I could go that low and still get some Rpms for highway use. Bout two grand goin 55. Love the way it drives. Dumped bottle of Lucas in tranny and car shifts good and stays in gear. But I know it's gonna go soon. Wanna slap in new improved transmission like a 5 or 6 speed. Auto since I don't wanna hang a clutch. Any one knows who offers options for a 94 5.0 gt.
Schlahty is offline   Reply With Quote
Old 02-11-2011, 09:34 AM   #2
Titus Wadicus
svtlx's Avatar
Re: 4.10 gears autp tranny
sooo u wanna install a 5 or 6 spd auto? to my knowledge they are all computer controlled..be a serious challenge for a pcm set-up for an aode. not to mention, i dont think the 5 spd autos ford makes will even bolt up to the back of a 302.
you can definatley install a 5spd manual...possibly a 6spd, but dont quote me on that. it wouldnt be all that hard.
you could install an aod or an aode automatic...
im sure someone here may be more knowledgable than me on this and will chime in....
good luck.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-11-2011, 10:48 AM   #3
good luck.
I think svtlx is pretty much right on unless the aftermarket has built something special for a 302.I think your auto tranny options are limited
Old 02-13-2011, 12:43 AM   #4
Schlahty's Avatar
Region: Oregon
There are some transmissions available for a 94. 2500$ is probably the ballpark price. They have aode with short and tall first gear or wide or close range gears. It'll be s pretty penny for sure. By then I'll have my liscense back. Otta get a scrambler. Speeding tickets are spendy these days.
Tranny! Nrooney3 1996-2004 Mustang GT 15 02-10-2011 09:56 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
tranny gears oaktonarcher Pre-2005 V6 Mustang 9 07-08-2004 03:24 PM
Is it expensive to get gears changed on an automatic tranny? DropTop_Stang Pre-2005 V6 Mustang 19 08-23-2003 01:36 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
09:32 PM
