4.6 in a fox? - Mustang Evolution
Old 02-13-2011, 04:52 PM   #1
Qwik Four Six's Avatar
4.6 in a fox?
Don't think it would mount up, but can you put a 4.6 from an 06 gt in a 93 coupe??
Qwik Four Six is offline   Reply With Quote
Old 02-13-2011, 04:53 PM   #2
MC770's Avatar
Re: 4.6 in a fox?
Probably can but my guess is that your going to have to fab up some special mounts for it
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 02-13-2011, 04:53 PM   #3
bbunt302's Avatar
Re: 4.6 in a fox?
It's been done before. Not sure on the details though.
I was just thinking today that putting a new modular 5.0 in a Fox would be a really fun project...
Scary stuff.
Old 02-13-2011, 05:02 PM   #4
Yea. I thought about that, engine mounts.
Old 02-13-2011, 05:03 PM   #5
Yea, it'll cost a little bit to get a new 5.0 though.
Old 02-13-2011, 06:54 PM   #6
Re: 4.6 in a fox?
Coyote engine can be ordered for a little over $6K.
93CobraGuy is offline   Reply With Quote
Old 02-13-2011, 07:02 PM   #7
Lol. Yea, but my dad found an 06 4.6 and was lookin at getting it, he also found a few 5.0's that he's looking at to replace his 289.
Old 02-13-2011, 10:37 PM   #8
bbunt302's Avatar
That's a pretty good price if you ask me. Do you know what all that comes with?
If I could get everything I needed, including a 6 speed tranny for under 10k, I would be really tempted to give it a go. 412 hp from a reliable, stock motor is hard to beat. Plus I could leave all the 5.0 badges on.
Scary stuff.
Old 02-13-2011, 11:01 PM   #9
Re: 4.6 in a fox?
Here it is on LRS. Helluva deal if you ask me!
2011 Mustang Ford Racing 5.0L Crate Engine, M-6007-M50 at LRS - Same Day Shipping!
Old 02-13-2011, 11:34 PM   #10
Las0mbra's Avatar
That would go nicely in my 2004 v6 XD
Old 02-14-2011, 06:54 PM   #11
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
94-03 k member bolts up in a fox....and vice versa. saleen made a 2000 stang with a 351 pushrod. one of my friends that races put a 4.6 in his 91 gt, you have to convert manual brakes cause the booster wont fit past the head. and if your really good....u can stuff a 4v in a fox too, but u have to trim sum shyte then. 5.0 mag did an article a while back, but they always do shyte the hard way.....
it's been done many times over...that's where i got the idea to put the 5.0 in the 97.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-14-2011, 07:04 PM   #12
Oh okay. Might get a 3v?
Old 02-14-2011, 07:08 PM   #13
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
u may wanna get experienced with wiring up the 4.6 electronics first....lol before graduating to the 3v or 4v
Old 02-14-2011, 07:36 PM   #14
Well, my dad knows, and it'd be for him.
Old 02-14-2011, 07:48 PM   #15
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
ok...well i know that stickn a 5.0 in up to 03 isnt all that bad... dropn a 4.6 in a fox is the easy part...wiring it up is another...so i wish you guys luck. all the exhaust for the 4.6 will work on fox up to 03. as far as 3v or 4v...ill have to source sum articles and write ups i have. i know 5.0 mag did a whole 03 cobra 6spd swap into a fox. u definatley would need a whole car to swap with though...
Old 02-14-2011, 08:27 PM   #16
May not do it. It'll be a job, my dad found a 351, hasn't looked at it, the guy doesn't know if it's a Windsor or a Cleveland, but it's cammed, roller rockers, etc. for $600. We've found some good deals on craigslist.
Old 02-14-2011, 08:30 PM   #17
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
get a 94-03 v6 and drop in your 351...you could do carb or efi...go efi!!
Old 02-14-2011, 08:47 PM   #18
Plus 1.... Efi is so much more reliable and fuel efficient. Well more efficient than a carb anyway. If it's just a track car a holley dp would be awesome but if it's a daily driver efi all the way. Instead of trying to make the wiring Harness work perhaps a stand alone fuel injection like quarterhorse or megasquirt might be an option.... Just a thought
Old 02-14-2011, 08:51 PM   #19
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
good idea...but they are pretty pricey. thats y i just a get harness from the junk yard.......aftermarket harnesses can run 500 buks and way more...
Old 02-14-2011, 09:39 PM   #20
Yea, but remember, my dad has the 93 coupe to work with. And, he's gonna leave it carbed. Mines carbed, but I like efi more.
Old 02-14-2011, 09:47 PM   #21
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
ok...im lost...so u guys gonna do a mod motor in a fox..or a pushrod in a sn95 body?
Old 02-14-2011, 10:29 PM   #22
Lol. Well, might just get a 5.0 and put it in there, I created the thread to see more details about a swap, if he found a good cheap 4.6 But whatever motor we get, is going in a 93 coupe to replace a 289.
Old 02-14-2011, 10:45 PM   #23
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
well u could do the 4.6 carb set-up too, but i dont even know where to begin to tell u where to even find a harness for that app..or intake for that matter. serously though, if i were u...sometimes simple is more. id get sum 351 swap headers and drop in a roller 351 from the junk yard out of a 95 van or pick-up. ad a nice intake and cam with your carb and call it a day..
Old 02-15-2011, 02:53 AM   #24
Just find a 302 and built a 400 hp tire shredding n/a torque monster
Old 02-15-2011, 03:37 AM   #25
Go for it man. I would go after a 2 valve instead of 3v. From what I've seen the 2v holds up to more punishment.
Alscobra is offline   Reply With Quote
Old 02-15-2011, 04:02 AM   #26
Yup....,they can take alot of abuse.
Old 02-15-2011, 09:20 AM   #27
I know the 2v is good. I wad just sayin we found a good 4.6 from an 06 gt. But my dad likes carb better, so we'll stay carbed if we get a 302 or 351 off craigslist. Not goin to a junkyard. Lol
Old 02-15-2011, 09:27 AM   #28
Re: 4.6 in a fox?
You mean like this?
High Flow Performance
Old 02-15-2011, 11:30 PM   #29
Titus Wadicus
svtlx's Avatar
Re: 4.6 in a fox?
sooo when u say a 400hp 302...you mean a stroked 347. cause you aint getn 400hp outa a n/a 302 with a carb...or efi for that matter.
let me re-phrase it... you can get 400hp out of a 302..it just wont run on gasoline...and the heads on it will cost more than most of us can afford in todays economy...lol.
94 v6 - VS - Fox 5.0 sledgehammer Pre-2005 V6 Mustang 1 03-04-2008 04:44 PM
Someone with a fox.... fast64 Mustang Wheels & Tires 1 12-26-2007 08:00 PM
T-56 for fox? Can'tCatchMe 1979-1995 Mustang GT 13 01-30-2006 09:14 AM
Might be getting another fox soon.. MonteCitan The Bar 29 04-14-2005 09:19 PM
What ya think of this Fox? lowflyn The Bar 29 01-22-2005 09:50 PM
02:16 AM
