Extra fan nosie i think?? - Mustang Evolution
Old 02-17-2011, 10:58 PM   #1
Los905.0's Avatar
I hope someone can help with this, I changed the fan clutch and fan and after I made the change I got a loud wind blowing sound. It only happens when I first start the engine and then if I'm at idle for a few minutes then it goes away I think. Well at least I think this is coming from the fan but I could be wrong all together. If someone can help me with this problem do I need to change the fan clutch again or is it something else. HELP ME PLEASE!!! thank you.
Los905.0 is offline   Reply With Quote
Old 02-18-2011, 09:26 AM   #2
stampde's Avatar
Re: Extra fan nosie i think??
those 5.0 fans DO Make a lot of noise , there's probably nothing wrong with it
do you have a fan shroud ? that tends to mask the wind noise
2011 GT Auto
Old 02-18-2011, 10:09 AM   #3
Titus Wadicus
svtlx's Avatar
it's normal dude...my 04 ram does the same thing.. not to mention my old gt did too. you are fine bud.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-18-2011, 05:56 PM   #4
Los905.0's Avatar
Yea I do have a fan shrud I was worried because it never made that noise before just all of a sudden. So if I went to a electric fan I would be better off then, what do you think?
Old 02-19-2011, 12:34 AM   #5
Titus Wadicus
svtlx's Avatar
seriously..it's fine... it makes noise now cause you got a fresh clutch in it.
Old 02-19-2011, 12:39 AM   #6
+1
93CobraGuy is offline   Reply With Quote
Old 02-19-2011, 01:00 AM   #7
You are missing the electric fan you should have replaced it with.
Alscobra is offline   Reply With Quote
Old 02-19-2011, 01:31 AM   #8
Los905.0's Avatar
Yea thought about putting an electric fan in but I didn't and just went with the replacement fan an clutch.
Old 02-19-2011, 01:36 AM   #9
Man I gotta see if I still got part numbers. I had numbers on a really nice prewired relay kit and a fan that fit in the stock shroud perfect.
Old 02-19-2011, 01:38 AM   #10
I'll probably just do a Taurus fan on the vert sometime.
Old 02-19-2011, 01:45 AM   #11
There was a really nice relay kit from gm I used all the time. Waterproof, fusible link, ground strap, perfect for fans. I got the part # somewhere.
Old 02-19-2011, 02:14 AM   #12
Los905.0's Avatar
Well if u run across it shot it my way I'll check it out.
engine nosie iwannagofast 1996-2004 Mustang GT 4 02-25-2008 02:05 PM
This is why you carry a gun and extra ammo at all times Brent The Bar 51 06-16-2006 10:36 PM
Wouldn't it be nice if you had an extra life like in a video game? Seph The Bar 11 04-04-2006 11:04 PM
DAMN!! if only I had an extra 1500!!!! sonic04edge The Bar 7 11-15-2005 05:28 PM
Do I want the free wireless card or the extra battery? Brent The Bar 12 11-08-2005 08:49 AM
05:11 PM
