High ppm's - Mustang Evolution
Old 02-18-2011, 08:04 AM   #1
High ppm's
I recently took my newly purchased 1990 mustang gt for emissions test. It failed twice because the vehicle ran 734 ppm & the max should be 220 for the state of Texas. Before the first failure I added magna flow cats and after the first failure I fixed some vac hoses that had leaks and adjusted the timing and idling and needless to say I failed again. What else can I do? Any help will be greatly appreciated.
Ben513b is offline   Reply With Quote
Old 02-18-2011, 08:16 AM   #2
Do you still have a smog pump?
Alscobra is offline   Reply With Quote
Old 02-18-2011, 09:46 AM   #3
Re: High ppm's
No, it does not have a smog pump. Do I need it? Could I also adjust the fuel regulator?
Thanks
Old 02-18-2011, 09:46 AM   #4
Titus Wadicus
svtlx's Avatar
Re: High ppm's
im gonna assume you are talkn bout a 5liter motor.. ppm stands for "parts per million" the 220 ppm is whats called an "allowable limit" a standard usualy set by the state e.p.a.
how old are your plugs?..... and what are they gapped at?
is the cam stock?... if your running aftermarket cam, it prolly wont pass regardless of how many cat converters you throw at it. aftermarket cams tend to be very inefficient at idle and lower rpm.
check and clean your mass air... are you runing a oem or aftermarket mass air...
what do you have the timing set at? 10,12,14 degrees?
what kinda coil are you running?
do you have an msd box?
we really need more info on your set-up to give you better suggestions
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-18-2011, 10:04 AM   #5
stampde's Avatar
Re: High ppm's
SVTLX , Good stuff ...+ 1
2011 GT Auto
Old 02-18-2011, 11:15 AM   #6
Thanks
If your car came with a smog pump, you r probably gonna need it. There are some tricks but you gotta know what your doing.
Old 02-18-2011, 04:04 PM   #7
SaleenFiend's Avatar
Re: High ppm's
I didn't know Texas tested the emissions so tough. You guys are worse then us.
Old 02-18-2011, 04:10 PM   #8
Ha ha I'm in St.James parish. We still have a $10 sticker. Headlight and horn check. It's great.
Old 02-18-2011, 04:30 PM   #9
Re: High ppm's
Lucky. I'm an State Inspection / OBDII / Commercial Certified Inspector, but it still blows my mind on some of these things. Also, I admit the work arounds are pretty simple.
High beams Rascal Pre-2005 V6 Mustang 2 03-20-2010 08:51 AM
Is this dude high? iwannagofast 1996-2004 Mustang GT 12 09-26-2009 11:34 PM
The High Came and Went bluemustang The Bar 28 03-01-2007 02:33 PM
Mile High? Sexylil66 The Bar 35 10-18-2006 12:54 PM
A little high? n8r The Bar 10 02-13-2006 01:14 AM
07:49 PM
